Audio 20 Aux wiring question iphone/ipod - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-28-2012, 08:54 AM Thread Starter
Jay Perry's Avatar
Date registered: Apr 2011
Vehicle: 2010 Mercedes Benz C300 Sport
Okay, I have the basic audio 20 in my 2010 W204 with no NAV, no MM, nothing. I recently bought a cable that connects via the iphone dock connector (not headphone jack) to the 3.5mm aux connector in the glove box. Sounds great but I would need to know if anyone has had success in running a cable out of the glove box into a more accessiable area in the center console? The current cable is 6ft, can buy longer or extenders if necessary. I'm about to upgrade an JL sub in the trunk and Focal seperates for the front stage with an external amp. Any suggestions would be appreciated.
Jay Perry is offline
post #2 of 11 (permalink) Old 02-28-2012, 09:51 AM
Date registered: Jun 2009
Vehicle: 92 MB 400E, 99 BMW R1100RT, 00 BMW 323i Touring, 05 MB C230, 07 Chevy Tahoe LTZ, 07 Silverado Z71
Quoted: 801 Post(s)
Not sure if somebody has done it, but I don't see why you wouldn't be able to just get a longer cable and run it inside the center console to the desired location. Shouldn't be a big deal.
You just need to disassemble enough stuff out of the way so that you have good enough access.
TexFinn is online now
post #3 of 11 (permalink) Old 03-03-2012, 07:44 AM
Date registered: Jan 2012
Vehicle: 08 C350 Sport (W204)
Because aside from removing the iPhone cable, there aren't any holes to run another cable through without drilling/cutting through the material. I'm assuming that's why he asked because I'm facing the same dilemma.
illlojik is offline
post #4 of 11 (permalink) Old 03-03-2012, 02:00 PM
Date registered: Feb 2012
Vehicle: 2007 SL550; 2013 GLK350 4Matic; 2010 E550 4Matic Sedan
Sure.
http://www.benzworld.org/forums/w211...k-reroute.html
With the W204 it's even easier.
Alan in Denver
It once was theorized that an infinite number of monkeys typing randomly on an infinite number of keyboards would, in time, replicate the works of Shakespeare.
Thanks to Internet message boards, we now know that this is not the case.
PilotAlan is offline
post #5 of 11 (permalink) Old 03-03-2012, 09:09 PM
Date registered: Jan 2011
Vehicle: White 2009 C300 Sport
or better yet, drill another hole in the side of the glove box and bring out the aux port, and then get this,
TuneLink Auto hardware accessory for iPhone, iPod Touch & iPad
it basically lets you play music from any ipod or phone with bluetooth, through the car speakers, and the best part is when u turn the vehicle off, your music stops, and when the device gets power (turn the key), it auto connects and starts playing music,
i think it would be better then taking things apart and running wires
kHuNkHuNa is offline
post #6 of 11 (permalink) Old 03-05-2012, 09:12 AM Thread Starter
Jay Perry's Avatar
Have you used this Tunelink before, just wondering if has any kinks or bugs and if the SQ is still good by going through the AUX input. I have a 12V outlet in my glovebox along with the AUX input so this may be the best option.
post #7 of 11 (permalink) Old 03-05-2012, 09:35 AM
it works perfect in the glove box because you can plug it in the aux port in there, also I found the sound quality to be best through MP3 discs, and then it was a bit quitter throughout the iPod aux cable, and through the bluetooth it was the exact same quality as it is via a auxiallry cable, but it is the quietest out of all three methods, i just had to turn up the volume a bit more with the tune link attached to the aux port, but i ended up returning my tune link because i needed money and just use my old iPhone 3g loaded with music that stays in my glovebox hooked to the iPod aux cable.
post #8 of 11 (permalink) Old 03-06-2012, 08:21 AM Thread Starter
Jay Perry's Avatar
Does the Tunelink affect the factory bluetooth used for phone calls in any way? I don't want to lose the funtionality of the current setup with indash microphone and playback of calls from the stock stereo system.
post #9 of 11 (permalink) Old 03-06-2012, 09:13 AM
i have an iPhone 4S, and it connected via bluetooth to both devices, so i could use the stock head unit to use the calling function handsfree,
you have to set your head unit to aux mode, and unplug any iPods if you have the iPod aux cable as well
post #10 of 11 (permalink) Old 04-08-2012, 09:47 AM
Date registered: Nov 2007
I ran mine from the glove ox to the ashtray. I hide my iPod in the ashtray now and just close it when I'm parked.
AMGCLS68 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
    Improved audio quality using iPod integration and iPhone 3G q little55 Audio & Telematics Forum 0 01-07-2009 05:36 AM
