Originally Posted by brownb2110 I was just quoted $188 for service. Said they need to remove the front panel to get to it.
Can someone send me the steps that were posted if you can find them.
Thanks |
aw man that is the biggest rip off of all time... WOW!
You can buy a set of brand new smoked or clear markers on ebay for only $50 and install them yourself in 5-10 mins...
step 1 - turn wheel inward on the side you are replacing so you have more room to work with (you wheel need to start car and do this for each side
step 2 - pull out 3 plastic push pin plugs under wheel well so you can pull back the plastic liner
step 3 - pull back plastic liner from bottom edge and get it up just enough so it goes over the painted lip of your fender... now you should have enough space to get your hand in there
step 4 - turn bulb to release from sidemarker assembly and remove
step 5 - pull apart side marker assembly and remove by unlocking the one tab on the inside housing that is locking the two pieces (outer lens and inside housing part) together
step 6 - replace with new markers, put every thing back in reverse order
do at your own risk, not responsible for any damage you do to your vehicle... these are only an outline of basic steps, and if you do not feel confident doing yourself please take to local body shop
