» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 11-14-2009, 10:06 PM   #1 (permalink)
Date registered: Apr 2009
Vehicle: '01 R129 SL500 & '08 W204 C300
How long did your OEM brake pads/ rotors last?
I've got an early production '08 W204 "C300" 7Gtronic anyway 36K miles and the other day I noticed a slight squeak when slowing to a stop. When I washed the car the other day I reached in and felt the rotor surface and noticed I could feel a lip along the edge of the rotor that led to believe I'm close to needing new rotors?
Just curious how many miles you guys have gotten out of your oem brake components. And do I need to take the car to the dealer for brakes or can I have an indy do it for less? Looks like the rotors are a special type with the holes drilled in for cooling and such. How much does the dealer typically charge for pads & rotor replacement. I was told that you don't resurface "drilled rotors" thanks in advance.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,
but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
"Wow! What a Ride!"
Two Benz Garage is offline   Reply With Quote
Old 11-15-2009, 07:54 AM   #2 (permalink)
Sunday morning bump
Old 11-16-2009, 08:40 AM   #3 (permalink)
Date registered: May 2005
Vehicle: 08 C300w Sport Loaded
Send a message via AIM to PrincetonBenz
I have 41k on my early 08 and are still on my stock front brakes. I replaced the rear brakes myself to get rid of the break dust. I am sure that around 50k, I will have to do the front...if I have the car by then.
rob
Current: 08 VW R32
PrincetonBenz is offline   Reply With Quote
Old 11-16-2009, 10:02 AM   #4 (permalink)
Ron Jr's Avatar
Date registered: Mar 2008
Vehicle: 2008 C300 Sport
rear pads changed at 22,500 but I think the dealer ripped me off as they had looked fine to me.
"A Brabus Maybach," he said, as she turned her head in time to see him give the wheel a little pat. "The firm of Brabus extensively tweaks the product of Maybach, to produce one of these."
"Darth my ride?"
From chapter 17 of Spook Country by William Gibson
Ron Jr is offline   Reply With Quote
Old 11-16-2009, 10:29 AM   #5 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
37.5 K on my 08 C300, original brakes. I'll see how much pad is left at the 39K service.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport Pkg. smoky granite metallic/gray
2002 Jeep KJ 4wd Sport white/gray
MB-SV is offline   Reply With Quote
Old 11-16-2009, 11:05 AM   #6 (permalink)
Tristram1's Avatar
Date registered: Aug 2007
Vehicle: 08' C350 Sport, 08' Porsche Cayenne S, 98' Ferrari 355 Spider
54,500 miles on a very early '08, 350 and originals at all four corners with no discernable difference in stopping power nor any indentified noises. I drive about 110 miles each day in heavy highway traffic so I have been pleasantly surprised with the longevity of these breaks compared to all of my past Benz’s.
08' C350 Sport
Palladium Silver over Charcoal
Tristram1 is offline   Reply With Quote
Old 11-19-2009, 01:01 PM   #7 (permalink)
MB-SV's Avatar
Are you on original tires still, if so what brand/type?
Old 11-21-2009, 01:55 PM   #8 (permalink)
Date registered: May 2009
47k, still on stock ones
dimkausa is offline   Reply With Quote
Old 11-22-2009, 12:05 AM   #9 (permalink)
saurey's Avatar
Vehicle: C300 Sport, Paladium Silver
How did the brake dust go after you changed them? I want ceramic but can't find them.
saurey is offline   Reply With Quote
Old 11-22-2009, 07:27 PM   #10 (permalink)
Date registered: Jan 2008
My rears were done due to the revised part, had to work hard to convince them to do it, but had that done about a year into ownership.
Car is now 2 years old with 24,000 miles.
Before my service B, I checked front pad, and they looked thick to me.
On my Service B, they wrote on the check list, 10mm front and rear. If I'm not mistaken, 10mm is a significant amount of pad left ?
2008 C300 Sport with P2 Package
2009 SLK 350 with P1 & Heating
mika911 is offline   Reply With Quote
How long should brake pads and rotors last? Mike Wevrick W220 S-Class 13 01-14-2009 07:32 PM
OEM Brake Rotors and pads chem1441 W208 CLK Class 1 10-17-2006 12:37 PM
Non-OEM Brake Pads / Rotors used on W220 DMI+RY W220 S-Class 0 02-23-2005 09:30 AM
oem brake pads and rotors mesallem W163 M-Class 0 09-15-2004 04:57 PM
Where to order OEM brake rotors and pads? John in Norcal W202 C-Class 3 10-09-2002 11:08 AM
