» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 07-01-2009, 09:01 AM   #1 (permalink)
Date registered: Dec 2008
Vehicle: 2007 c280 4-matic
oil change pump
Could someone please give me a recommendation on the best vacuum oil pump unit to purchase for oil changes C280.
ccmnova is offline   Reply With Quote
Old 07-02-2009, 12:23 PM   #2 (permalink)
Date registered: Oct 2008
Vehicle: 2008 C350 and a Lightning.
Motive Products 1708 - Motive Products Power Extractors – SummitRacing.com
I just used mine for the first time. It worked awesome and was the easiest oil change I've ever done.
It doesn't move the oil real fast and I did have to pump it a few times (don't go over 15" of vacume) but no big deal.
And, it sucked 8.5 quarts out so I would say it got pretty much all of it.
2tonOfun is offline   Reply With Quote
Old 07-02-2009, 12:54 PM   #3 (permalink)
Thanks for the tip - I'll get the same one ! - I have a 2007 C280 - where is the oil filter located ?!
Old 07-02-2009, 01:34 PM   #4 (permalink)
on top of motor, front, just to drivers side of center. 14 point cap about 3" dia.
There is a good diy here or on one of the forums.
Old 07-02-2009, 02:14 PM   #5 (permalink)
Vehicle: 1990 190E, 1998 ML320, 2005 ML500SE
MityVac 7201 in one that is used by many Benz owners but I do like the one mentioned above.
Mike
Mike's ML is offline   Reply With Quote
Old 07-02-2009, 07:50 PM   #6 (permalink)
I searched and couldn't find the diy -
Old 07-03-2009, 11:36 AM   #7 (permalink)
Date registered: Mar 2008
Vehicle: 08 C350
here you go.
http://www.benzworld.org/forums/w203...2007-c230.html
theinmoe is offline   Reply With Quote
Old 07-03-2009, 02:09 PM   #8 (permalink)
Thanks theinmoe,
That's the one. I couldn't find it either for some reason but there ya go.
Old 07-09-2009, 07:28 PM   #9 (permalink)
I actually got the mityvac unit and changed the oil the other day. The vac was difficult to get going and would constantly stop. I suppose you have to have the expandable rubber plug in the unit but the manual makes no mention of this. I had to keep pumping every so often to keep it flowing - maybe I was doing something wrong? The local Advanced Auto had Mobil 0W-40 and a Puralotor filter in stock that is marked - "Mann Filter" made in Germany.
Other than that the oil was simple to change with all work on top. The plastic lines on the mityvac - don't know what to do with them and they have oil still in them - coiled them up and just hung them in the garage - do you have to clean the unit out or will it be OK with the old oil remaining (what's left of it)?
Oil change pump??? AlanS W124 E,CE,D,TD Class 11 06-07-2009 06:05 PM
Oil Change with Vacuum Pump - opinions adrianmcronin W124 E,CE,D,TD Class 22 06-08-2007 05:06 AM
Transmission oil change with oil pump sam 100 W202 C-Class 8 12-14-2006 06:16 PM
oil pump change GreenGiant W126 S,SE,SEC,SEL,SD,SDL Class 5 01-14-2005 06:34 AM
Anyone got a link to the oil change pump that holds 8 quarts (or more)? Brian_R170 R170 SLK Class 7 09-13-2003 09:19 PM
