How to change rear brake pads? Any DIYs? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-12-2009, 09:09 AM Thread Starter
Date registered: Jan 2008
Has anyone seen online a DIY to change rear brake pads on a W204?
I ask because of the defective rear brake pads my car came with. I have too many miles for free replacement, but it only costs $60 to buy them myself, so I just want to do it myself.
However, is the car too new to find any DIY online?
Thanks so much.
2008 C300 Sport with P2 Package
2009 SLK 350 with P1 & Heating
mika911 is offline
post #2 of 7 (permalink) Old 02-12-2009, 10:59 AM
Date registered: Nov 2008
If you know brakes, it can't be very hard. If you haven't changed brakes much in the past, you probably should not be doing them yourself on this car. Usually it is simply: remove wheel, either 1/remove caliper mounting bolts and lift off disc or 2/undo brake pad retainer and swing out, then remove pads being careful to avoid damaging the clips/squealers. push piston back into cylinder with a c clamp, and insert new pads. Ideally, get the rotors turned, or replace them if damaged or under thickness. Take care to protect the ABS components, of course. Reassemble. I've probably installed a half million sets of rear brakes (I worked in a car plant), have done so on every car I've owned, and I would not hesitate to change the brakes on the W204 myself. I always put new disks on to be sure everything is perfect and to save the time it takes to re-do.
SRoss is offline
post #3 of 7 (permalink) Old 02-12-2009, 11:59 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
The rear brakes seem so similar to other MB models that almost any existing DIY guide should be sufficient. Should not be too difficult even without any DIY guide.
Diesel Benz is offline
post #4 of 7 (permalink) Old 02-12-2009, 12:10 PM
Date registered: Jan 2009
If you have done brake job before in your other vehicles, I don't think you'll have much trouble.
Looks like a perfect excuse to get some drilled rotors to match the front ones.
javavu is offline
post #5 of 7 (permalink) Old 02-12-2009, 12:53 PM
one.bofh's Avatar
Date registered: Jul 2006
Vehicle: 2008 C230 4MATIC; 2008 ML320 CDI 4MATIC
Good call! Anyone know how much those would cost?
92% of all people suck at math. I am a part of the 9% who don't.
Current Cars:
2008 ML320 CDI 4MATIC (W164) - Silver/Black
2008 C230 4MATIC (W204) - White/Black
Past Cars:
2002 E320 (W210) - Silver/Black - Sold due to rust
one.bofh is offline
post #6 of 7 (permalink) Old 02-12-2009, 02:14 PM Thread Starter
I just want to replace the defective pads. I'm sure the rotors are fine.
Is there a brake pad sensor on the rear pads or only front?
Finally - Yes I have done brake pad changes before. Does Mercedes put some kind of squeak stuff on the piston side of the pads? If so, what kind? Like the aerosol stuff?
Thanks!!
mika911 is offline
post #7 of 7 (permalink) Old 02-12-2009, 05:29 PM
Date registered: Aug 2008
just be aware 99% of all foreign cars have screw in rear pistons. there is a special adapter you need to screw the piston as you compress, auto zones will lend you the tool with a deposit for free, a cheap tool can be had for 20 bucks, pro about 60. If youve done disc brakes B4 its the same. use the blue aerosal around the whole backs, there is a sensor, and grease the caliper slides and brake pad holder slides
demetrios007 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
    Is it okay to change front brake pads and then change rear pads about a month later? jay (new jersey) R170 SLK-Class 5 07-17-2012 01:12 AM
    Getting ready to change brake pads....confused as to which pads I need??? Help ml320here W203 C-Class 10 07-07-2012 04:41 PM
    w123 rear brake pads=VW beetle front pads? eurobluebenz W123 E,CE,D,CD,TD,TE Class 9 05-09-2006 07:28 PM
    Official Now: My original rear OEM brake pads lasted 74, 500 miles. I bought new OEM pads, a brake AC_ML W163 M-Class 2 02-07-2004 05:25 PM
    Thanks for pics JimB, changed brake pads this weekend no problems, frt pads had more wear than rear Dave L. W163 M-Class 13 02-25-2002 10:48 PM
