"Correct Tire Pressure" - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 10-13-2008, 12:28 PM Thread Starter
palaobok's Avatar
Date registered: Aug 2008
Vehicle: Mars Red Mercedes Benz C300
Send a message via AIM to palaobok
I have been receiving this message in my dashboard for quite awhile now. Maybe around 2-3 weeks? I have a c300 and new to the brand and was just wondering how i should come about to this problem. Any help would be appreciated. Thanks!
palaobok is offline
post #2 of 16 (permalink) Old 10-13-2008, 12:54 PM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
Did you check and adjust tire pressure in all 4 tires (cold) to recommended pressure?
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #3 of 16 (permalink) Old 10-13-2008, 02:44 PM
Date registered: Sep 2008
Vehicle: 2008 C350 - Multimedia Package
If the tire pressure is correct on all four, I believe you can reset the system to recognize the current pressure as the correct pressure.
Matthew121170 is offline
post #4 of 16 (permalink) Old 10-15-2008, 07:24 AM
Date registered: Oct 2004
Vehicle: 2006 C280
Uh.....all of the above, and read the manual???
John R.
Vancouver WA
2006 C280
History: '69 220/8 [OSD]; '71 220/8; '73 SE 4.5; '76 300D; '77 240D; '78 240D; '79 300SD; '81 300SD; '84 190E; '86 190E; '89 260E; '94 C220; '98 E320; '02 C240; '06 C280: '08 C300; '10 GLK350; '14 GLK250
jrct9454A is offline
post #5 of 16 (permalink) Old 10-15-2008, 07:37 AM
MB-SV's Avatar
Quoted: 77 Post(s)
page 344
Read section on TPMS starting on page 344 in manual.
S.
MB-SV is offline
post #6 of 16 (permalink) Old 10-15-2008, 08:57 PM
Date registered: Jul 2008
Vehicle: 2009 C300 Sport 6MT, 2007 BMW 550i Sport 6MT, 2000 Mazda Miata 5MT
I had similar situation when I changed tire pressures from 32 all around to 30 front & 32 rear (I reset the system after the change). The manual didn't help...
I found that this sequence (step 1 to 4) will re-produce this message pretty reliably:
1. In the morning, turn on the engine.
2. Before you move the car, reset the system to use current pressure.
3. Drive away.
4. In a few minutes, this message ("Correct Tire Pressure") shows up. No other red/yellow error/warning icon(s).
5. Reset again (while driving), this message will be cleared and will never come again.
Don't understand the logic of this message...
mx5_dvr is offline
post #7 of 16 (permalink) Old 10-16-2008, 09:33 AM
eXists's Avatar
Date registered: Jan 2008
Vehicle: C350 - Steel Gray + MM + 18" AMG + IPod
I've been getting the same thing every now and then for the past 3 weeks as well (weather getting colder?), checked the tire pressure yesterday and seems ok so reset the setting in the menu after you've checked the tire pressure and think it's ok.
eXists is offline
post #8 of 16 (permalink) Old 10-16-2008, 09:30 PM
Date registered: Dec 2007
Vehicle: '15 C400, Formerly '11 C350 - Formerly '08 C300
I was getting the "correct tire pressure" warning after the dealer filled the tires with nitrogen - the warning came on after turning off ignition at end of every trip, tried resetting baseline when cold, still got warning at end of trip... pressures were ok, took to dealer, no more warnings but they did say the pressure was low all around..
sjelevokter is offline
post #9 of 16 (permalink) Old 07-21-2009, 04:54 PM
saurey's Avatar
Date registered: Mar 2008
Vehicle: 2012 C350 Coupe, Palladium Silver,
I can't seem to kick the TPMS "Check Tire Pressure (in red)" and "Correct Tire Pressure" messages. Took it in to mechanic, everything looked fine. I F*CKING hate these useless TPMS's. Every time I get in the car I get this message. I've tried the manual calibration to no avail. I'm thinking of going to a gas station, letting out air, calibrating, drive around block, then put air back in to 30 F, 32 R.
saurey is offline
post #10 of 16 (permalink) Old 07-22-2009, 12:03 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
All who get TPMS warning messages (without a tyre problem), either try over-inflating a bit or have the TPMS control unit programmed to allow a bit lower absolute minimum tyre pressure.
The point is that the system works with two figures, the learned target when the user activates the system (or the system activates itself new thresholds when it detects tyres being inflated) or the lowest allowed figure. One cannot set the monitored level lower than the system minimum. Also if the set value is too close to the minimum, minor variations tend to bring the warning. See earlier posts, several owners have had the system calibrated for new minimum levels.
Of course one should be absolutely sure about the gauge accuracy when checking tyres.
Diesel Benz is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
    "Stupid Question" What is the right tire pressure? Heretic E55 W210 E50 AMG, E55 AMG 10 11-02-2010 12:31 PM
    "Check Tire Pressure" Light Won't Go Out Vac General Mercedes-Benz 0 12-27-2007 11:47 AM
    Correct 19" tire size and Wheel offset on a 2005 C230K Sedan gwalker35 The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 01-04-2007 09:41 PM
    tire pressure on 20" geralmjcj The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 06-24-2006 09:38 PM
