I have an abnormal noise that comes from inside the dashboard. Sounds like a coin is inside the dashboard but there's none. It sounds like it's coming from behind the center of the dashboard more towards the right side, probably behind the center LCD display. The service department of a dealer worked on it and said it's a loose harness behind the radio. I took it home yesterday and the noise is still there. I will take it back again. Does anyone have this unfortunate problem? Do you know a similar post about this in the past?
I have the same problem, did you manage to find the problem. For me it is intermittent, so it would be really useful to be able to tell the garage what they need to look for.
