» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 07-13-2008, 06:06 AM   #1 (permalink)
MY2008ML350's Avatar
Date registered: Mar 2008
Thumbs up Safety feature
I found this safety feature by accident:
When closing your window, when it hits an object during the process of closing (such as an arm), the window will go down instead of continuing to go up preventing an accident to happen (such as a severed head- yuck! ). Didn't know about this feature nor can't find it in the owner's manual. You guys can also try but be warned in case the feature will not work for you.
BTW, I also tried it in my ML, also works !! (Also not in the owner's manual)
2008 ML350, Obsidian Black, Premium Pkg
2008 C300W Sport, Calcite White, COMAND NAV, 7G-TRONIC
2007 C230W Sport, 040 Black,Prem Pkg,7G-TRONIC (gone)
MY2008ML350 is offline   Reply With Quote
Old 07-13-2008, 11:09 AM   #2 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
btw, sunroof has same safety feature.
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 07-13-2008, 08:04 PM   #3 (permalink)
Date registered: Apr 2008
Vehicle: 2008 C350 5th Avenue Special Edition, 2007 SLK350
my friends jag has the same feature. he rolled up the window on someones arm and it went back down
Dieffenbach is offline   Reply With Quote
Old 07-13-2008, 08:51 PM   #4 (permalink)
Date registered: Jan 2008
Its called the "Pinch control". Bit like a garage door that reverses it self if it hits an obstruction. Mainly to stop accidents with little kiddies fingers and necks.
Sometimes they get hyper active and there is a section in the manual on how to reset the feature.
HTH
keith100 is offline   Reply With Quote
Old 07-14-2008, 12:41 PM   #5 (permalink)
Bad if you're trying to escape from someone trying to get into the car by putting their hands and arms in at your and or the locks.
2008 C300 Sport with P2 Package
mika911 is offline   Reply With Quote
Old 07-14-2008, 01:02 PM   #6 (permalink)
MB-SV's Avatar
HTH
Yep. Look how the power window switches are designed, again for the safety of kids.
Old 07-14-2008, 07:11 PM   #7 (permalink)
...Sometimes they get hyper active and there is a section in the manual on how to reset the feature...
Can you also reset kids so they don't get hyper ?
Old 07-15-2008, 05:54 AM   #8 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
I would just hold the window up button although I don't believe my w203 has this feature.
Tri-Star is offline   Reply With Quote
Old 07-15-2008, 10:06 AM   #9 (permalink)
Date registered: Sep 2005
Vehicle: 2002 ML320 - Capri Blue!!
That's why you just drive off. Does the pinch control work if you hold the button and not just do auto up? I tested the auto up pinch control with my brother's arm a long time ago but I don't want to try it when I hold the button.
asianml is offline   Reply With Quote
Old 07-15-2008, 02:13 PM   #10 (permalink)
Laughed at that just as I posted it Glad to see someone saw the humourous side.
Just discovered safety feature! Corkscrew General Mercedes-Benz 5 02-11-2008 10:41 AM
can a faulty left front speed sensor activate the ets safety feature falsely? busoptr W163 M-Class 4 07-16-2007 09:29 PM
I just find out one interesting about "lemon law", if your car have problem with safety feature.... Linh R170 SLK Class 3 07-16-2002 02:01 PM
cool new feature on the E class, wat is the function, safety light? Import Tuner Typ R170 SLK Class 10 07-15-2002 03:15 PM
New safety feature from MB... Norb USA R170 SLK Class 4 04-01-2002 10:55 AM
