» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 06-22-2008, 12:12 PM   #1 (permalink)
Date registered: Feb 2008
Question Compressor runs with AC Off.
When I get close to my destination, I usually turn off the AC compressor. I've recently noticed that it keeps putting out cold air.
Is there a time delay in the AC compressor switch that keeps it on for a while when I turn it off?
Thanks.
Pierre
2008 C300 Luxury 4Matic.
Bellavance is offline   Reply With Quote
Old 06-26-2008, 12:43 PM   #2 (permalink)
Date registered: Jun 2008
I've noticed that too. I will turn off the AC, and cold air will keep rushing out...any ideas?
mrariaz is offline   Reply With Quote
Old 06-26-2008, 02:04 PM   #3 (permalink)
I've noticed that it will take about 5 minutes for cold air to stop coming out. It seems the A/C compressor stays on for roughly 5 minutes after you turn it off.
Old 06-27-2008, 06:53 AM   #4 (permalink)
Wiggums's Avatar
Date registered: May 2008
I have a habit of turning on and off air conditioners.. I am really convinced there's a very long delay if you turn it off then back on.. it blasts hot air and this is VERY annoying. Same thing turning it off, it still stays cold for a few minutes!
Wiggums is offline   Reply With Quote
Old 06-27-2008, 07:16 AM   #5 (permalink)
Date registered: Apr 2008
Vehicle: 2008 C300 Sport 4Matic
I would think that the issue isn't that the AC is still operating, but rather that air is still being blown through the previously cooled unit. As the unit warms back up, the air blown warms also. If you want warm air blown in your face as you arrive at your destination, turn the AC off sooner.
More importantly, why are you turning the AC off at all?
posnera is offline   Reply With Quote
Old 06-27-2008, 08:46 AM   #6 (permalink)
I'm turning it off so the evaporator gets a chance to dry a little before I stop the car. If I did otherwise in my previous cars, even when they were almost new, there was often an A/C smell when I would start the car afterwards, probably caused by stagnant water. So I took the habit of turning it off one minute or so before coming home.
Old 06-27-2008, 08:50 AM   #7 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Must be an MB thing, my ML350 also does this. No big deal.
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 06-27-2008, 02:29 PM   #8 (permalink)
Date registered: Jan 2008
I've only noticed that smell after a few yrs, and then I start doing what you do too. Maybe too late.
The Manual says there is a delay in shutting down the compressor, but even after that you still get cold air as the chiller looses its cold. My house system is the same, so maybe its some sort of "cycle down" protection for a/c systems generally.
keith100 is offline   Reply With Quote
Old 06-27-2008, 08:36 PM   #9 (permalink)
Wiggums's Avatar
In my case, I turn the A/C off when going up hills. I live in a fairly hilly area and probably due to my budget-conscious years as a teenager I'd downshift with the A/C on while going downhills then turn the A/C off while going up hills. I don't even think it made much of a difference... but... I find myself doing that nowadays!
ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 13 07-28-2008 07:32 AM
92 300E Runs for awhile, dies, sit for a short while then runs again... russ g W124 E,CE,D,TD Class 2 09-25-2007 07:24 PM
A/C Compressor runs permanently wakpo0 General Mercedes-Benz 0 10-30-2006 12:06 AM
$15 5-in-1 air compressor for those that bought used SLKs with missing compressor Black98SLK230 R170 SLK Class 2 11-29-2004 03:20 PM
