No playable files? Memory card - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-17-2008, 08:45 AM Thread Starter
Date registered: Mar 2007
Question No playable files? Memory card
Hi guys I have a SDHC card with a PCMCIA memory reader but for some reasons the MP3 files doesn't play all I get is NO PLAYABLE FILES.
What am I doing wrong?
I try files directly from Ipod also try to convert them into MP3 files but all says NO PLAYABLE FILES.
2008 C350
1991 560SEL
1981 300SD
1983 300SD
rebel_mtc is offline
post #2 of 5 (permalink) Old 05-20-2009, 02:57 PM
Date registered: Mar 2009
I have the same problem
Did you find how to fix ?
bast regards
pqft is offline
post #3 of 5 (permalink) Old 05-20-2009, 11:10 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
First you have to check that the adapter is SD HC capable, older adapters only support SD cards (typically up to 2 GB).
Next the files have to be MP3 files with appropriate parameters. Even iTunes should be able to do it although aac would be the default which isn't compatible.
Diesel Benz is offline
post #4 of 5 (permalink) Old 05-21-2009, 02:20 AM
Date registered: May 2009
at least you have to have the latest comand firmware. Early versions (< Aug 2008) don´t fit.
Peter
peterhabo is offline
post #5 of 5 (permalink) Old 05-22-2009, 04:48 PM
thank you very much
my car is 2009
its work now , the problem was that i use my macbook pro to send the MP3 files to SD and CF cards, and he double the file Nr. for index its contents ,when i delete unwanted index files its working now
pqft is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Memory Card sagers2 W221 S-Class 46 01-14-2013 09:25 PM
Any Success with memory card slot?? jayfly22 W204 C-Class 31 08-24-2008 08:19 PM
PCMCIA playable files? rebel_mtc W204 C-Class 0 06-07-2008 09:43 AM
maximum memory card capacity? posnera Audio & Telematics Forum 4 05-28-2008 08:51 PM
Memory card slot for 2007S Corkscrew W221 S-Class 0 02-21-2006 01:00 PM
