» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 05-11-2008, 12:21 PM   #1 (permalink)
Date registered: Mar 2008
Vehicle: W204 sport
17x8 48offset FIT
I picked up my 2008 C300 4-matic yesterday. But I just notice front and rear has different tires sizes. I am trying to get a set of 17x8 48offset wheels. Will 245/40/17 fit on a 8" wheels?
Thank you
et0201 is offline   Reply With Quote
Old 05-11-2008, 01:50 PM   #2 (permalink)
GPI
Date registered: Nov 2006
Vehicle: W204
Yes, I'm pretty sure that it will fit.
GPI is offline   Reply With Quote
Old 05-13-2008, 01:09 PM   #3 (permalink)
Vehicle: W204 sport
I hava a 08 C300 4-matics and the size of the wheel I want are out of stock.
They only have 7.5JJ×17 OFF40 PCD112. I used the offset calculator on tirerack and it shows the Outer Position for the front will be 7mm more and 5mm more in the rear. This size is orginal for w210.
17X8 wheels/will fit ??? hyprr1 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 06-26-2007 11:28 AM
Will 17x8 et 38 fit Addbhp W124 E,CE,D,TD Class 10 03-24-2007 05:05 PM
17x8.5 " ...will they fit ? benzer04 W126 S,SE,SEC,SEL,SD,SDL Class 3 05-05-2004 07:15 PM
will 17X8 ET 28 wheels fit on w124 300E? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 05-15-2002 09:45 PM
235/65/17 tire on a 17x8 or 17X8.5 wheel for a 2000 ML320? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-29-2002 10:26 AM
