» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 03-31-2008, 01:59 AM   #1 (permalink)
Date registered: Sep 2007
Stuttering Sun roof
My sunroof has been stuttering when I try to close it ... I thought something was wrong but when I looked it up in my manual, it says it's because it's no longer synchronized.
I tried to follow the directions to synchronize it, but no luck. Anyone have any experience with this??
Thanks!
katmeleon is offline   Reply With Quote
Old 03-31-2008, 06:37 AM   #2 (permalink)
Date registered: Mar 2006
Vehicle: 98 ML320, 2008 C300 Sport MT
I have the same problem closing my sun roof. I just dropped off my car to MB service. They said it could be in program. I should get my car back today and let you know how it goes.
supersnakeking is offline   Reply With Quote
Old 04-01-2008, 12:25 PM   #3 (permalink)
Got my car back yesterday. The sunroof is fixed by dealer. They told me the issue was fixed by doing calibration.
Old 04-23-2008, 12:07 AM   #4 (permalink)
Date registered: Mar 2008
Vehicle: C300 Sport, Paladium Silver
I got mine Repaired and "Synchronized" by the dealer, then tonight It started stuttering again. I can't be dropping my only car off at the dealer every time this breaks so I am going to have to complain about it. Maybe I can do the job myself.
Where did you find it in the manual?
saurey is offline   Reply With Quote
Old 06-11-2008, 07:46 PM   #5 (permalink)
Date registered: Feb 2008
Stuttering? Maybe this is the issue I'm having too. I can't open or close it without having to push the button over and over again.
Is this what you guys mean? My sunroof no longer opens with one tap or push and hold. I have to open and close it by pushing it over and over.
Adanac is offline   Reply With Quote
Old 06-11-2008, 10:25 PM   #6 (permalink)
Date registered: May 2008
Similar thing happened to mine today. I can open the sun roof all the way with on touch button but I would have to hold on to it when I try to close. I am planning in taking it to the dealership because I gotta go in for maintenance anyways.
tommy8501 is offline   Reply With Quote
Old 06-12-2008, 10:29 PM   #7 (permalink)
The Workshop MB's Avatar
Date registered: Apr 2006
Vehicle: 1988 300 TE. 2001 ML 55AMG. 2003 ML350 (now the new service vehicle...)
Overhead control panel
Sounds like the OCP is losing memory. Happens a lot in CLK Class, and I remember it happening in the C Class (203). Just a guess, but if you like, I will research the MBZ bulletins to see if this is a recurrent thing that MBUSA is aware of and has put out a bulletin.
Also, if you can get the part number of the overhead control panel, call any dealer, and if it is in stock, then that is the problem.
Most times (97%) of the time, if a part is in stock, then that part is the problem.
Happy Benzing!!!
www.theworkshopmb.com
Authorized Kleemann Dealer
Free, 27 Point Inspection!
0% financing on all upgrades.
The Workshop MB is offline   Reply With Quote
Old 06-13-2008, 11:04 AM   #8 (permalink)
Apparently Germany is aware of this problem on the 204 and is currently working on a fix. It's a software problem.
Old 06-13-2008, 02:18 PM   #9 (permalink)
Dealer said that a software update in July is coming so when I get my 6K mile serve it will be available.
Old 07-01-2008, 08:53 AM   #10 (permalink)
Date registered: Nov 2004
Vehicle: 2001 CLK430 Silver
Sun Roof Problem Fixed
I brought my '08 C350 in on Monday, June 30th and I was later told after they looked at the issue that the UPDATED SOFTWARE is available but only on a CASE BY CASE basis. Since I had brought it in with the same issue once before they applied the software update.
I've only had the car back for one day so I don't know for sure if this has fixed the problem but my sunroof is working again with all the 1-Touch features of open, close, vent.
I'm not sure that the dealer would apply the software on the FIRST TIME you brought your car in for the issue but I'm sure you could press them into doing so.
Good luck if you're having similar issues.
loganboyd is offline   Reply With Quote
Sun roof operation kjhayes007 W203 C-Class 14 12-12-2007 01:57 AM
Sun roof adjustment? per300 W126 S,SE,SEC,SEL,SD,SDL Class 0 11-21-2007 02:06 AM
sun roof bullet361 W126 S,SE,SEC,SEL,SD,SDL Class 3 03-13-2006 07:21 PM
Sun Roof Problem benjak W124 E,CE,D,TD Class 9 08-23-2005 04:26 PM
No sun roof needed!!! MB_Racer R170 SLK Class 12 09-26-2001 01:07 PM
