Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 12-21-2007, 02:48 PM   #1 (permalink)
Date registered: Sep 2007
Need help Replacing Front Fog Lamps
Hi, I would like to know if anyone kno how to get to the front Fog lamps for replacement? Or where i can go to in this forum to get that info. Thanks!
yosheego is offline   Reply With Quote
Old 12-24-2007, 07:39 AM   #2 (permalink)
Date registered: Nov 2007
Vehicle: 2008 MERCEDES C300 4MATIC P2 PANO ROOF
You would need to take off the wheels and take off the plastic clips and screws that hold the fender lining. You don't have to remove all of them. Just remove enough to be able to stick your hand in to remove bulb. Owner's manual said that it uses a h11 bulb, but its not. It uses h7 bulbs.
brighton1 is offline   Reply With Quote
Replacing front turn signal lamps jjpeter_1996 W203 C-Class 9 11-20-2006 04:11 PM
Aux headlight fog lamps and after market fog lamps alc W163 M-Class 21 11-04-2005 11:59 AM
What is the lamp style for the front fog lamps injexeng W210 E50 AMG, E55 AMG 1 11-05-2004 07:35 AM
replacing front fog light bulbs... ewalberg G-Class 4 02-09-2004 11:13 AM
Has anyone tried replacing the regular LENS to a clear lens on the fog lamps? ImportTunerTyp R170 SLK Class 1 12-12-2002 01:55 PM
