WHICH GAS GRADE TO USE FOR c300?? - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 11-02-2007, 08:23 AM Thread Starter
Date registered: Oct 2007
Smile WHICH GAS GRADE TO USE FOR c300??
Hi, I just purchased a c300. It says to use premium gas 91. At the gas station where I usually go, there is mid grade 89 and premium 93. The dealer says I can mix the two grades of gas. Should I do that or just always use the Premium 93 gas or is that not good to do? Thanks!
mercedes7 is offline
post #2 of 17 (permalink) Old 11-02-2007, 08:27 AM
GPI
Date registered: Nov 2006
Vehicle: W204
I would suggest that you use the premium 93 grade. It is better and more convenient than having to mix two types of gasoline. I always use the highest octane gas(which is 92) for mine.
GPI is offline
post #3 of 17 (permalink) Old 11-02-2007, 09:23 AM
Project6's Avatar
Date registered: Dec 2004
Did the dealer really say that? Mechanic or Sales Rep? Has anyone mixed grades of gas before?
160k and counting
PROJECT6
www.stepintomyshoes.wordpress.com
Project6 is offline
post #4 of 17 (permalink) Old 11-02-2007, 11:02 AM
rj.laroza's Avatar
Vehicle: C300
i use 91.. dealer said to use that.
i really wouldnt mix the 2 gases.. although i do not know much about it, it doesnt sound smart @ all... just go with the 93.
2008 Mercedes-Benz C300 arctic white. black mb tex. panorama roof. amg twin spoke alloy wheels. premium I+II package. multi media pkg.
rj.laroza is offline
post #5 of 17 (permalink) Old 11-04-2007, 06:52 PM
Date registered: Nov 2007
Vehicle: 2006 Subaru Impreza
Unless you do extreme driving such as towing, high-altitudes, etc., you can get by on regular. Of course, you didn't buy a MB because you're cheap enough to actually do that, right?
Some places offer 91. More than that is a waste, but won't hurt unless maybe you get into non-standard fuels. Less than that, the engine will compensate and probably lose 2 or 3 hp that you won't notice. Mixing grades is fine, again, the car will determine what concoction you fed it and react appropriately.
If you decide you want a few more horses and you don't need the warranty, you can probably have the engine's computer reprogrammed for use with 93 or 94 octane ONLY.
Qest is offline
post #6 of 17 (permalink) Old 11-05-2007, 01:44 AM
B-McD's Avatar
Date registered: Aug 2005
Vehicle: '79 450 SLC
Send a message via MSN to B-McD
If it says use 91, use 91 or higher. Its not a lawnmower, its a $40K car.
B-McD is offline
post #7 of 17 (permalink) Old 11-05-2007, 03:53 AM
Vehicle: 2008 c300 luxury P2, Multimedia.
well, if you read the manual, and your car happens to be one that can use either premium OR E85, than you should use one or the other...the manual specifically says that you should NOT mix these 2 types, and you should only "switch" between the 2 when your tank is less than 1/2 full..I plan on trying E85 when the tank gets down, but, it also says do NOT use E85 when the temperature is below 14 degrees F, which, here in chicago land will be pretty soon!
So, I would say whatever fuel you use, if you change grades, wait until your take is less than 1/2 full..
wase4711 is offline
post #8 of 17 (permalink) Old 11-05-2007, 08:54 AM
E85 will give you more power and fewer miles to the gallon, but you should triple-check to be certain your particular car is compatible with it as not all 2008 C-classes are.
Qest is offline
post #9 of 17 (permalink) Old 11-05-2007, 09:18 AM
Tri-Star's Avatar
Date registered: Aug 2007
Vehicle: C320 4matic
i mix gas every other trip to the pump ... between premium and mid so like 91-93
Tri-Star is offline
post #10 of 17 (permalink) Old 11-05-2007, 10:54 AM
Yes, on the inside of my gas filler door, it tells me that I can use E85 in this car..
As far as mixing premium with mid-grade, I am not sure that is such a good idea; what kind of results have you had while doing that, Tri-Star? Any rough idle or hesitation?
How many miles on your car?
wase4711 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W204 C-Class
What grade gas do you use? Tbilisi79 W140 S-Class 25 01-07-2011 04:51 PM
Middle-grade gas Ghee W203 C-Class 11 10-16-2006 04:39 PM
Middle grade of gas(89) ok with 2000 SLK 230? get real R170 SLK-Class 5 03-12-2006 06:09 AM
Grade and types of gas Vs. performance soman11 W203 C-Class 13 08-30-2004 10:04 AM
Will < 93 grade gas damage the SLK230? pcm2a R170 SLK-Class 9 11-24-2002 09:51 AM
