Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 10-19-2007, 01:31 AM   #1 (permalink)
Date registered: Aug 2007
Bluetooth and Blackberry
I picked up my C350 today and I was trying to connect my Blackberry Curve to the bluetooth phone system in the car but my blackberry keeps noting "unable to connect." Any ideas to help connect my phone to the car?
It finds a device called "Audio Sound" but for some reason doesn't connect.
Any comments would be appreciated.
c350vancouver is offline   Reply With Quote
Old 10-19-2007, 11:56 AM   #2 (permalink)
opeler1900's Avatar
Vehicle: 2008 C300 Sport
Send a message via AIM to opeler1900
This can be a headache. try to do the reverse discovery method. Rather than the Car try to find the phone do and external authorization and try to find the car with the blackberry. That should work for you.
Derek
opeler1900 is offline   Reply With Quote
Old 10-19-2007, 12:15 PM   #3 (permalink)
Bluetooth pairing
Check out http://www.mbusa-mobile.com/finder.php for a possible solution.
Barrypps is offline   Reply With Quote
Old 10-19-2007, 01:14 PM   #4 (permalink)
Date registered: Oct 2007
I'm glad someone else asked about the Curve
I see it isn't listed on the website as one of the compatible BBs...does that mean it can't be paired?
Gatercedes is offline   Reply With Quote
Old 10-19-2007, 02:14 PM   #5 (permalink)
Vehicle: 2008 c300 luxury P2, Multimedia.
no, that listing probably hasnt been updated in a long time..
go to the dealership service department, and someone there shoudl be able to help you..
wase4711 is offline   Reply With Quote
Old 10-19-2007, 04:57 PM   #6 (permalink)
opeler1900's Avatar
Derek
Also even the Mercedes-Benz Training literature on the topic says that you have to do the pairing two times before it works. Just try it again. I always use the reverse External method.
Old 02-28-2008, 11:20 AM   #7 (permalink)
Date registered: Feb 2008
I just picked up a 2008 C350. I tried to pair my Blackberry from either the car or from the phone nothing appears to work. The care recoginizes the 8830 but that is it it will not pair. Any suggestions on the Blackberry settings.
avajda is offline   Reply With Quote
Old 02-28-2008, 11:55 AM   #8 (permalink)
Premium Member
AZ.Benz's Avatar
Vehicle: 2008 E320 BLUETEC
Premium Member
One common mistake drivers make is that they attempt to pair their phone with the engine running. The engine must be off for the software to connect, a safety feature.
Hope this helps,
AZ.Benz
AZ.Benz is offline   Reply With Quote
Old 02-29-2008, 01:11 PM   #9 (permalink)
White2008c300sport's Avatar
Vehicle: 2008 C300 Sport 4Matic
It took me awhile and many attempts to finally pair and transfer my address book. You just have to add it as new unit and follow the step by step instructions. It does work and it's awesome!
Kal
White2008c300sport is offline   Reply With Quote
Old 02-29-2008, 02:39 PM   #10 (permalink)
Vehicle: C-300
I have a Blackberry 8830 and was able to transfer the entire address book to the C-300.
On the Blackberry Bluetooth options screen you have to ensure you have set
- Address Book Transfer > All Entries
James B is offline   Reply With Quote
Bluetooth kit and Blackberry Ilpaco W164 M-Class 10 06-12-2007 07:16 PM
Bluetooth Puck and Blackberry? dorfman24 Audio & Telematics Forum 1 05-05-2007 10:13 AM
Anyone using Blackberry with Bluetooth? oknish GL Class 10 01-13-2007 10:41 AM
BlueTooth and Blackberry 7130C msarway W221 S-Class 4 10-29-2006 03:06 AM
Blackberry Bluetooth Adapter SoxFan Audio & Telematics Forum 4 05-03-2006 08:48 PM
