Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 09-24-2007, 06:15 PM   #1 (permalink)
Date registered: Sep 2007
10 Miles on C300 Sport and Running really hot??
I currently purchased a C300 and its running pretty hot. It stays at 80 or above. Has anyone encountered this?
ChrisCA07 is offline   Reply With Quote
Old 09-24-2007, 06:18 PM   #2 (permalink)
nokoter's Avatar
Date registered: Aug 2007
mine stays between 80 and 100...
nokoter is offline   Reply With Quote
Old 09-25-2007, 03:28 PM   #3 (permalink)
Date registered: Oct 2004
Vehicle: 2008 C300 Luxury
It's supposed to run between 85 and 95C....ours stays pegged at 90C through thick and thin....we've encountered 110F outside temps for days on end, and the gauge never budges once it's warmed up. Relax, everything's fine.
John R.
Vancouver WA
2008 C300 Lux
White, Black Tex, P1, Auto.
History: '69 220/8 [OSD]; '71 220/8; '73 SE 4.5; '76 300D; '77 240D; '78 240D; '79 300SD; '81 300SD; '84 190E; '86 190E; '89 260E; '94 C220; '98 E320; '02 C240; '08 C300
jrct9454A is offline   Reply With Quote
Old 09-27-2007, 08:39 AM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
85 degrees celsius is only 185 degrees farenheit. That is nowhere near hot for a modern car.
Once you get above 210 farenheit or about 99 degrees celsius, then you can start to worry.
OliverK is offline   Reply With Quote
Old 09-27-2007, 09:50 AM   #5 (permalink)
frans-c's Avatar
Vehicle: 1985 W123 Mercedes-Benz 230E
From what I've read (not from experience), modern cars' temperature gauges indicate it's normal running temperature for all temperatures between 60 - 110 degrees celcius, i.e. it will indicate 90 for all the aforementioned temperatures. So, your car may indicate 90 when it's actually running at 100 degrees (surely you would've noticed the fans kicking in?).
Personally, I think I would prefer the old-style gauge that shows how the temperature fluctuates.
F R A N S
1985 Mercedes-Benz 230E
340 000 km / 211 000 miles
Full MB service history...still
frans-c is offline   Reply With Quote
Old 09-27-2007, 11:33 AM   #6 (permalink)
that would make no sense. You are saying that the gauge is marked improperly, and that 90 is really up to 100, and 100 is really 110?
My 210 temp gauge fluctuates in traffic and it runs a tiny bit warmer on really hot days or with the A/C on.
Old 09-27-2007, 01:18 PM   #7 (permalink)
frans-c's Avatar
No, that's not what I'm saying. What I'm saying is that the temperature gauge will indicate it's normal running temperature, e.g. 85 degrees celcius with ALL temperatures between 60 and 110 degrees. Only below 60 and above 110 will the needle deviate from 85.
I may be wrong, but I'm aware of quite a few modern cars (don't know about the W204) that operate on this principle.
Motorweek Online Review of C300 Sport BKHammond W204 C-Class 2 09-25-2007 03:35 PM
Can I Special-Order Parktronic for US C300 Sport? BKHammond W204 C-Class 8 09-18-2007 05:02 PM
Just ordered an C300 Sport eddie081 W204 C-Class 1 09-13-2007 01:35 PM
running a little hot mikroehl W202 C-Class 2 02-08-2006 02:53 AM
running a little hot mikroehl W202 C-Class 0 02-07-2006 04:41 PM
