Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W204 C-Class
Old 09-15-2007, 07:57 PM   #1 (permalink)
Vehicle: 2008 C300 4M Cubanite Silver & 2000 SLK 230M
Winter Rims and Tire Pressure Monitors
I've ordered an '08 C300 4Matic which will arrive in November and I am now shopping for winter tires and rims. TireRack says you need to install a pressure sensor in each rim - cost $284 - to sync with the car's tire pressure monitoring system. (I could move the sensors from the summer rims but it defeats the purpose of having winter tires mounted on their own rims).
If I don't install the monitors, does anyone know if the monitoring system in the car can be disabled or will I be looking at a warning light all winter long?
Ted in Toronto is offline   Reply With Quote
Old 09-15-2007, 09:33 PM   #2 (permalink)
Rick Hunter's Avatar
Date registered: Sep 2007
Vehicle: '08 W204.081; M 272.948 KE30; Colour Code#792
AFAIK, you'll be seeing the annoying light all through Winter if you don't have the TPMS installed.
Also, I believe Audi, BMW & M-B use TPM sensors made by Beru AG (German company). it works off 433MHz, and the embedded battery lasts for ~8 years. So $284 over 8 years isn't too bad... get 'em!
Just make sure the wheels you'll be getting can accommodate the sensors. Some wheels do not.
Rick Hunter is offline   Reply With Quote
Old 09-18-2007, 01:59 PM   #3 (permalink)
Date registered: Jul 2007
....TPMS is US only for now.
Canadian cars have normal rims with the "dumb" pressure monitoring system (same as B-Class) that uses the ABS sensors to detect a major change in tire diameter.
....so, good news, you can put regular rims on for winter....your dealer probably has a package.
berenyi is offline   Reply With Quote
Old 09-18-2007, 06:11 PM   #4 (permalink)
Berenyi:
That's great news, I prefer "dumb" wheels with no sensors (somehow I've survived 40 years of driving without them). The dealer gave me the build list and it lists Accessory Code 477 - Tire Puncture Warning - so I assumed that was the TPMS that TireRack says I need to purchase the sensors for.
Do I have to change my tire pressure with new rims?? Darkmann The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 06-05-2006 07:41 PM
Winter Tire & Rims OEM W211 ALL E-Class 2003 UP peterdemet For Sale, Trade & Wanted Items 2 05-14-2006 11:16 AM
Luke - Tire Pressure Monitors on ASA ST3 Carl_in_DC The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 10-20-2005 10:06 AM
18" AMG Rims with P285/60R18 Tire Pressure? N1ML W163 M-Class 9 01-11-2004 11:45 AM
Winter tire sizes for stock slk32 rims??? alanmb R170 SLK Class 7 09-09-2003 02:47 PM
