» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 11-13-2009, 02:27 AM   #1 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
Replaced Power Steering Pump
2002 C32 AMG with 90k miles. Fluid started to leak through the pulley shaft. When it gave out there was loud power steering noise, and bad vibration in the steering wheel. Fluid in the reservoir was foaming up. Cheapest re-manufactured power steering pump I could find was $400 after core refund. Dealership pump is brand new $650 dollars no core refund. Figured it was worth the extra money for a new pump...
25-140MPH C32 AMG
Dynocom 327.6WHP / 374.3WTQ
2002 C32 AMG Sedan [97,000 Miles]
3.2L Supercharged v6 M112K (22+ PSI)
Clear Side Markers - CL Style Grille - Flat Hood Emblem
NGK Iridium IX - Magnecor KV-85 - 185MM LET & LET ECU
PSK Belt Wrap - Y-Splitter Intake - Boost & A/F Ratio Gauge
Dual Cone Filter Intake - Carbon Fiber Front Spoiler
2002c230 is offline   Reply With Quote
Power steering box and power steering pump thoth_9 W123 E,CE,D,CD,TD,TE Class 7 09-15-2009 08:51 PM
Power Steering Pump vs. Hydraulic Suspension Pump jdg15 W126 S,SE,SEC,SEL,SD,SDL Class 8 05-03-2009 06:31 PM
power steering pump, rebuild kit or used pump Tye W123 E,CE,D,CD,TD,TE Class 5 08-10-2007 09:27 PM
92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 06:58 PM
Get those power steering clamps replaced!!! cgeorge430 W163 M-Class 1 02-23-2003 07:05 PM
