» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 08-20-2009, 07:52 AM   #1 (permalink)
Date registered: Jul 2009
Vibration Between 40-50mph
My ride is c240 2002, 16" stock rims, 205 fronts, 225 rears, 60K miles, im experiencing a vibration at speed 40-50mph, below this speed the car goes smooth, 45mph is the worst and 50mph and up kind of fade away, i have search this forum, but there is real clear answer or solution. I have already take the wheels to the shop , to see i have a bent wheel, all were fine . Wheels have being balanced several times at different shops, i have rotated tires an wheels, with no effect on the feel of the vibration. Have done inspection of bushings and arms for wear componets but every looks neat. No play in the steering wheel. No crashes or accidents. I do need to correct camber according to the aligment experts, but thats not a reason for the resonance vibration. From reading the forums i gona try to replace the rear brake discs, this is the option that makes more sense to me, and the fact that they have never being replaced. Does any one have solved a similar situation?. I dont wanna waste money changing things that are ok.... just to see .. if the vibration goes away....
gercajr is offline   Reply With Quote
Old 09-04-2009, 05:35 AM   #2 (permalink)
unimoged's Avatar
Date registered: Dec 2008
Vehicle: 203, 201, 124, 123, 109, 108, 404
Check the drive shaft center support and the joints at the transmission and the differential.
unimoged is offline   Reply With Quote
Old 09-04-2009, 07:24 AM   #3 (permalink)
Thanks for your reply, i will try that!
Pavement to dirt road @ 50mph rawimpact W210 E-Class 1 12-28-2008 09:54 AM
vito speedometer bellow 50mph modesty V-Class 0 12-14-2008 02:25 AM
Car shakes at 45~50mph z168 W140 S-Class 36 04-11-2008 01:47 PM
89 drumming over about 50mph jester1a W201 190 Class 2 12-09-2007 03:46 AM
'93 300E wandering over 50MPH Gary C W124 E,CE,D,TD Class 2 10-18-2007 01:32 PM
