Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 04-30-2008, 02:16 PM   #1 (permalink)
Date registered: Jan 2008
Question Where is the MAF on C32?
Hello guys, My car is running slow when i gas it on the highway. I was thinking of changing my MAF sensor, But i don't see it anywhere. I called MB parts and they said the c32 doesn't use MAF, It something called the FLY?
Can anyone tell me where is the MAF located at on the C32?
THANKS IN ADVANCE
gtr886 is offline   Reply With Quote
Old 05-03-2008, 12:31 AM   #2 (permalink)
calimax's Avatar
Date registered: Oct 2006
This motor does not come equipped with one. It uses a MAP sensor in its place. You may be having an issue with the Intercooler pump. When this fails, the water in the Heat Exchanger will get hotter and cause the intake temps to rise to a point that the timing of the motor becomes pulled back to cut down power when knock has been detected, in order to preserve the motor. There are multiple options to resolve this, either replace the pump with another Bosch/Ford Lightning pump that sometimes last 30K or upgrade to the Johnson CM30/CM90. Also the best thing to keep the temp down consistently is to upgrade the Heat Exchanger. Here's a couple websites to get you started: Code3 Performance - Home and LET Motorsports - Mercedes Tuning and Performance
calimax is offline   Reply With Quote
Old 05-03-2008, 05:40 PM   #3 (permalink)
Arrow
Thanks for the info, i already replaced the IC pump with the MB original pump 3 weeks ago, its feels the same thing. i even replaced the radiator with nissens. its fast of take off but loss of power at 50mph+. any idea? should i upgrade the heat exchanger?
FS: C32 AMG airbox (candy apple red) fits M112 V6 for W203 & 55 y-splitter for C32. FrankW For Sale, Trade & Wanted Items 5 05-20-2008 10:48 PM
Cleaning the MAF sensors..? Seems that we don't need to be buying MAF sensors all the time..? AC_ML W163 M-Class 11 01-30-2008 03:49 AM
MAF after replacing maf! engine light came back on! help please. sgjacob@patmedia.net R170 SLK Class 35 11-15-2007 10:22 PM
C32 track thread on the C32 list... SteveL R170 SLK Class 0 10-13-2001 09:26 AM
SLK32/C32 Information - translated. Contains performace comparison of SLK32/C32 SteveL R170 SLK Class 0 06-13-2001 08:49 AM
