Does anyone know if the 2005 C55 has RCA jacks on the back of the radio. I am wondering if there is a way to connect a line for a 3.5 mini jack to connect it to an MP3 player. One of the options in the audio menu on the system is for Aux and I am wondering if this means there is some sort of line in for something like this. Any help would be greatly appreciated.
Vehicle: 05 C55, no nav, silver/black, Mahdi 19" wheels, tint
There is a audio cable you can purchase from your dealer. Someone here posted the step-by-step instructions last year for installing it. I did mine. It isn't hard, but the instructions are a must, since you need to access the wiring along the bottom of the passenger-side kick panel to find the connector that is there for you to plug in the connector on the audio cable. You then route the new cable up to the glove box, where there is a knock-out for installing the mini-jack fitting. The Aux input is then accessed by holding down the CDC button for a couple of seconds. I'll see if I can find the post and part number.
If you have any trouble, go to my profile and look at my previous posts. There is one dated 7/13/2007 about audio inputs, and in that thread there is one by "Avantgard ICE" dated 1/18/2007 that has all the info you need.
By the way, if you have Nav, this jack may already be installed in your glove box. It will be on the top of the right-hand side of the opened glove box, near the front. Good luck.
Thank you for your awesome response. I do have Nav and I have asked the dealer a couple times what my options were for this and why the AUX button was appearing on my system. Lo and behold the jack is already installed in the glove box right where you said it would be. Thanks again for your response. I am ecstatic.
