Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 03-20-2008, 05:46 AM   #1 (permalink)
Date registered: Mar 2008
Question Windshield Washer Pump Not Working
Hi,
I just bought a used 2003 C32 it runs and looks great. The only problem that I am having is that the windshield washer pump does not seem to work, if I push the lever in the wiper blades work but the pump does not even make any noise.
I tried to look for a fuse but the docs that I found in the inside fuse panel quotes that there is no fuse just say electronic.
Is there another fuse that I am not aware of, or could it just be a pump that has gone bad? My last toy was an 87 944 Turbo that had a couple of these pumps go.
Anyway thanks for any help in advance!
Chip
Turbochip is offline   Reply With Quote
Old 05-22-2008, 06:38 PM   #2 (permalink)
Date registered: May 2008
Bump, Anyone?
I have the same issue also :-(
Parker1961 is offline   Reply With Quote
Old 05-29-2008, 12:24 PM   #3 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 209000 miles
Probably dead pump.
macdrone is offline   Reply With Quote
Old 06-01-2008, 07:01 PM   #4 (permalink)
It ended up being the washer pump as stated above.
I pulled mine out and hooked up a volt meter to the wires. When i got a reading i drove to the stealership and picked up a new washer pump for 37.05 and a grommet for 1.56
Windshield Washer Pump in a C32 Turbochip W203 C-Class 0 03-20-2008 05:24 AM
Windshield washer pump(s) Arcee43 W163 M-Class 4 03-02-2008 12:11 PM
Windshield-Washer Pump dimon1980 W163 M-Class 2 06-05-2007 08:43 AM
Help! Windshield washer not working ColoradoE420 W124 E,CE,D,TD Class 1 01-01-2007 08:55 AM
Windshield Washer Pump DIY? 97C28O W202 C-Class 1 08-22-2006 01:45 AM
