Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 02-26-2008, 08:36 PM   #1 (permalink)
Date registered: Jan 2008
Question c32 transmision jerk When change Drive***
Hello, When i change the shift "D" from "R" it will jerk after 1 sec when the car is parked, is this normal? Whenever i put the car on "D" from park, it jerks.
gtr886 is offline   Reply With Quote
Old 02-28-2008, 11:50 PM   #2 (permalink)
Adullessence's Avatar
Date registered: Feb 2008
Vehicle: 2002 Mercedes C32 AMG-(19'inch Mandrus Millenium wheels),1998 Infinity I30
That doesn't sound good. A good friend of mine is a certified Merc Mechanic. I'll ask him about that. Few problems i've had he knows what it is before he even looks at it.
Ladies! My Mercedes! Holds 3 in the back, 2 if ya fat.
Adullessence is offline   Reply With Quote
Old 02-29-2008, 08:57 AM   #3 (permalink)
Says he wonders if someone spilled something in the shifter module assembly. May need a new shift select module control unit, Costly. Man let me know how that turns out, hopefully he called that wrong.
Old 03-02-2008, 11:31 AM   #4 (permalink)
~BANNED~
try ECU reset & Mass air sensor cleaning, sometimes those two can cure tranny shifting issues.
Dr. C36 is offline   Reply With Quote
Old 03-02-2008, 03:29 PM   #5 (permalink)
Date registered: Mar 2007
check trans fluid first. if the fluid is fine, than you may need a conductor plate and/or trans module.
Motioneffects is offline   Reply With Quote
c32 transmision jerk Justsaymo01 W203 C32 AMG, C55 AMG 2 02-28-2008 04:55 PM
TRANSMISION FLUID CHANGE 123CLOCK W126 S,SE,SEC,SEL,SD,SDL Class 6 07-16-2007 11:49 PM
112cdi will not change gears in drive clemmahoney V-Class 2 01-08-2007 09:46 PM
SLK32/C32 first drive on Motorweek SteveL R170 SLK Class 4 06-29-2001 01:03 PM
C32 available in 4matic? or able to drive in snow? Guest (MBNZ) W202 C36 AMG, C43 AMG 4 03-28-2001 01:50 PM
