» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 02-21-2008, 04:19 PM   #1 (permalink)
Date registered: Jul 2006
03 c32 air bag light need help
Ok my SRS light is on and ther is a message for 1 MALFUNCTION also says something about the safety restraint system in the center of the cluster. This happended when I hit the brakes pretty hard this never happened before this is the first time. I would like to know if there is a way I can reset this myself by pulling fuses or disconnecting the battery terminals, or is this something that has to get taken to the dealer. Tried the search without any luck any suggestions greatly appreciated.
AMG_Kid is offline   Reply With Quote
Old 02-25-2008, 02:19 PM   #2 (permalink)
BenzadiKtion's Avatar
Date registered: Sep 2007
honestly i think you fried the chip, my clk430 had the same problem...chip cost about 900$ or around there (just the chip!) AND I NEVER CHANGED I. when you slammed on the breaks it shorted the chip because it burned at such a qucik speed through your wires it couldve fried your chip. get it checked out and its probably that issue.
BenzadiKtion is offline   Reply With Quote
Old 02-25-2008, 05:07 PM   #3 (permalink)
Oh i see so this chip where is it exactly located and how can this burn out from slamming breaks. I had to slam them pretty good several times without issues and now this will fry the chip. Are the air bags still functional in case of colision then. thanks for the reply any more info would be great some of the techs gotta be on here.
Old 02-25-2008, 06:39 PM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
SRS light has to be reseted with the Star Diagnostic.
check both of your seat's module connection. There's a airbag sensor on the passenger seat. check your fuses. If all seem okay, just have your dealer run the Diagnostic and reset it.
OR you have broken either the front or rear SAM.
Carlsson RS bodykit/Weltmeister Quad/equal length shorty headers/resonator delete/BBS RE 18x8 18x9/Evilsport ODPS/ECU/TEIN SS coilover/Brembo 355mm/AMG 330mm/eibach sways/05 grille/Bi-xenon/Comand/intake y-splitter/green filter/brabus steering wheel/LED mirror blinker/05+ taillight/Euro impact strip/Carlsson CF spoiler/black interior trims/Carlsson shift-knob/Carlsson pedals
to do list: 1. wash and detail car
FrankW is offline   Reply With Quote
Old 02-25-2008, 06:45 PM   #5 (permalink)
uh...what? clk430 and w203 brakes are not driven by wire. you either have a bad from SAM or rear SAM. forgot which one controls the SRS. each SAM is around $300-400.
Old 02-26-2008, 09:14 AM   #6 (permalink)
ok cool thanks alot will check all these things this wknd and go from there I know the passenger seat has a loose box underneath where bunch of stuff is pluged in maybee something to do with that been like that since i bought it
Seat Belt light indicator & Passenger Air bag light on SLK350 2006 SLK350Benz R171 SLK Class 1 10-29-2007 03:19 PM
srs light and air bag off light ian campbell W163 M-Class 3 07-05-2007 02:47 AM
Air Bag And Brake Light SClegg42 W163 M-Class 4 01-17-2007 07:21 AM
Air Bag Off Light steve1173 R171 SLK Class 2 04-16-2005 04:28 PM
air bag light flashing HELP! woz W163 M-Class 2 01-22-2004 06:50 PM
