Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W203 C32 AMG, C55 AMG
Old 01-18-2008, 01:07 AM   #1 (permalink)
CCORLEY's Avatar
Date registered: Jan 2004
Vehicle: 99' ML430, 95' E300D
Posting for reference material: Transmission Leak
My 02 C32 began leaking transmission fluid about a month ago at 60k miles. I put the car up on ramps and it appeared to be leaking from the main tranmission pan seal. I took it into the dealer expecting to pay like 400.00 to have the seal replaced and fluid changed etc. It turned out to be the 13 pin connector that runs through the front of the transmission just above the main pan, located just behind the engine. It's apparently a sensor that controls the shifting of the transmission (what the dealer said?)The dealer told me that this was very common. It was replaced, added one quart of trans fluid, also detailed the hell out of my car and cost me $150.00. That was a great experience, that trip to the stealership
Just wanted to post this incase any of you run into this problem. I did some looking around and didn't see any other posts about this issue. I almost began tackling the trans seal myself, i'm sure glad I didn't...
~ccorley
~ccorley
2002 C32 AMG
1999 ML430
1995 E300D
CCORLEY is offline   Reply With Quote
Old 02-06-2008, 01:40 PM   #2 (permalink)
Date registered: Mar 2006
Vehicle: 2001 c240
Send a message via AIM to deesz
thanks for the info i am having shifting problems and i think my tranny is leaking im hopeing that this is the problem, what kind of fluid did they use synthetic non synthetic?
did you have shifting problems
deesz is offline   Reply With Quote
Transmission reading material bass1175 W140 S-Class 1 10-12-2006 03:35 AM
Transmission Leak GaryL W123 E,CE,D,CD,TD,TE Class 1 06-13-2006 02:25 AM
Transmission Rebuild Reputable Reference Request gwgng2 G-Class 3 03-02-2005 03:08 PM
Transmission leak shmelvin W140 S-Class 0 12-26-2003 12:23 PM
transmission leak Guest (MBNZ) General Mercedes-Benz 1 01-09-2002 02:09 PM
