2002 c230 a/c problems. EC Rest light will not go out. Help - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-17-2017, 10:01 AM Thread Starter
Date registered: Sep 2016
Help in getting a/c to come on needed!
Sent from my LGLS675 using Tapatalk
jmadisonpre is offline
post #2 of 8 (permalink) Old 06-17-2017, 12:14 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 438 Post(s)
No.
87 300D turbo + 5spd
93 190e 2.3 + Megasquirt 1
92 190e 2.6 5spd + Megasquirt 2 (parted out, history)
97 E300 DIESEL
02 C320 VAGEN :the ugly one!
tjts1 is online now
post #3 of 8 (permalink) Old 06-17-2017, 07:16 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 670 Post(s)
This means that the system cannot activate the compressor, which can be due to many reasons. Are you capable of repairing automotive AC systems? If so, we can offer some help of things to look at. If not, get it to a shop for a proper diagnosis.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is online now
post #4 of 8 (permalink) Old 06-19-2017, 05:59 AM Thread Starter
I can tackle a few tasks. Upto tearing down engine.
post #5 of 8 (permalink) Old 06-19-2017, 07:33 PM
rudeney's Avatar
Quoted: 670 Post(s)
If you have a set of gauges, check pressure on the system. If not, you can get a check AC recharge kit with a low pressure gauge and use that to at least check to see if the system has a charge. If not, then there's your issue - the system has leaked down. If you have pressure, it should be very high without the compressor running. In that case, it's probably the compressor itself or the pressure switch. To find out, you need to scan codes from the ACC system. A generic OBDII scanner won;t do it - you need SDS, or iCarsoft, or take it to a shop with an appropriate tool. Once you have the codes, then we'll know what is wrong.
- RODNEY
post #6 of 8 (permalink) Old 06-26-2017, 05:56 AM Thread Starter
I will do this this week. Thanks
post #7 of 8 (permalink) Old Today, 11:59 AM
Salal's Avatar
Date registered: Jun 2017
Vehicle: W210 E200K / S203 C220CDI / W169
If your EC light won't go out that's because the system won't let the compressor run as rudeney mentioned. if you have no pressure in the system there's your answer. If I remember on the w203 if the system gets below the minimum of 22psi the compressor will be deactivated. All AC system lose pressure naturally over the years of somewhat around 10% +/- refrigerant per year. so if your system is slightly low that could be the cause if your A/C hasn't been serviced in a long time but if you have no pressure in the system then you got a leak, which would need to be rectified.
Once again as previously mentioned, even if you refill the system, the compressor wont activate which you can't tell on these like the conventional ones as the pulley always spins but a variable swash plate deflects the pistons inside... You could try a reset on your air con control panel? I seem to remember that on some w203 models but i forgot which ones, it can reset the low pressure fault stored. You have to hold the recirc and windscreen defrost buttons together and the system will do a self bite test and actuate all the vent flaps and bunch of other magic... the lights should stop flashing after 2-3 mins. if they don't then it means you have a permanent fault which needs to be read which mentioned in previous posts and it could even be something stupid like the temperature/pressure sensor.
If you have a leak, which sounds likely, theres many well documentated guides online to find and fix A/C leaks online across all forums, its pretty much generic and doesn't vary much for a Mercedes! its worth fixing yourself if you feel confident enough, as most places can quote you a price that may even be worth the value of you car.
Salal is offline
post #8 of 8 (permalink) Old Today, 12:04 PM
Salal's Avatar
Also, don't forget, try to change your receiver/dryer cartridge which removes moisture from the system once your all done. this should be changed every time the system is opened/leaked out/serviced according to Mercedes, you can maybe get away not changing it if the system is properly vacuumed before refilling with refrigerent, but they are not that expensive so its worth doing.
On your postlift w203 it should be on the left side of the condensor (looking at the engine) where the high pressure port is.
Salal is offline
