Hi,
recently I got code P0410 on my C200 Kompressor, 2001 (M111 engine). I already made sure 2 valves (to the exhaust) for recirculation are functioning well and no leaks in the vacuum system.
Now I want to try to relearn the Recirculation Flap on the intake. I found procedure on a few forums, but I don't understand the process. Could someone here explain me in simple words how it is done?
1 When ignition is switched off press flap slightly past limp home
position. - IS THIS HORIZONTAL OR VERTICAL (open or closed?)
90° position must be changed manually. The processor
shut-off delay has a duration of approx. 5 seconds. (IS THIS THE NEXT STEP OR EXTRA INFO??)
2.Switch on ignition for approx. 15 seconds, switch ignition
back off again and wait for processor shut-off delay.
3. Switch ignition on for approx. 45 seconds, switch ignition
The learn-in procedure for the recirculated air flap is then
completed.
Help me please!!
If this doesn't work, should I buy a new flap? Or other suggestions? Clean throttle body? O2 sensors?
Thanks
completed.
Help me please!!
Thanks
