c203 c 240 2001 help!!! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-17-2017, 12:07 PM Thread Starter
Date registered: Apr 2011
hey my problem started when the car started doing 4 lights sign after I lock it, in the cuz of that the battery start to die in the morning till I turn it on with cables I taked the car to the main garage update the software and it stop blinking now the car battery start dying in cold moments like early morning or late night I had new battery but they told me it might me the problem so I changed it 4 days ago to bran new one, but sadly the problem not solved tryd get in the car in morning the car didn't go on to open other than with cables any one had this problem ?
wehab is offline
post #2 of 2 (permalink) Old 02-17-2017, 08:38 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 563 Post(s)
I'm having a difficult time following your post. Maybe you should try breaking it into multiple sentences. it seems you are having issues that would point to a bad battery, but the battery was replaced. I would check the voltage to see if there are no issues with the alternator or problems with a voltage drain. You should have 12.6v at rest, no less than 11v during cranking, and 14v at idle.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
