2002 C230 Kompressor Coupe: Key Remote Lock/Unlock Not Working, Key Won't Turn - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-03-2013, 11:42 AM Thread Starter
Date registered: Aug 2010
Ok, here are the details: last Sunday, I left my key in the ignition overnight, possibly in position #2 after shutting the engine off. This drained the battery by morning. So, I began a trickle charge and got new batteries for the key.
Once the battery was recharged, headlights worked, radio worked, lock/unlock dash control worked, dash info. lit up.
The key is recognized when put in the ignition (buzzing sound, steering unlocks), but the key does not turn.
Also, the remote lock/unlock function is not working.
I'm hoping there is a simple way to re-synchronize? The car was working fine before this happened. I'm not mechanically inclined, but it appears that the security system is not back on, either.
Should all automatically reset, or since the key was in the ignition when the battery drew down, maybe there are steps to re-sync?
I've found similar posts/issues, but none specific to my situation.
Any help would be appreciated.
Thanks...
AllstonRocks is offline
post #2 of 3 (permalink) Old 07-03-2013, 07:23 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 579 Post(s)
FYI, the batteries in the key are only used for RCL (remove central locking). The ignition switch function of the key is powered by an inductive coil in the EIS (electronic ignition switch).
Hopefully, the problem is simply that you battery is still too discharged to fully operate the vehicle electronics. Check the voltage - it should be 12.6v. If not, replace the battery. If that doesn't do it, then you may have killed your key. Do you have a spare (if not, you should get one - yes, I know they are over $200).
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #3 of 3 (permalink) Old 02-24-2015, 02:31 AM
Date registered: Feb 2015
I have a mercedes c180 kompressor and the key won't turn if I try to start the car even when I try to unlock thesteering nothing happens
kcshow89@yahoo.com is offline
