Originally Posted by Shawn_c230 Dudes, yeah my car fires right up no issues even -20. It just takes little longer than my Acura to warm up.
Schumicat - I have just replaced my t-state and maybe Sammy is right. I should not re-use the same coolant after replacing the t-state. If you guys know what type of coolant is appropriate for my car? |
u can either use zerex g05 or mercedes coolant from online or the dealer
make sure u mix the coolant with distilled water at the correct percentages
i think it be would be 60% coolant and 40% water for those negative temps but look it up first
ur acura is a v6 right? bigger the engine the more heat its gunna produce
