2003 C240 4Matic Coolant leak by left side rear tire - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-18-2012, 11:49 AM Thread Starter
Date registered: Oct 2012
Hello,
My 2003 C240 4Matic has a Coolant leak by left side rear tire which I just noticed a few days ago. My car has been in good shape, no issues all scheduled services done on time etc... My malfunction light doesn't indicate there is anything wrong.
Just wanted to see if anyone had any idea or experienced anything similar to this.
p_rodan is offline
post #2 of 10 (permalink) Old 10-18-2012, 03:22 PM
Date registered: Jan 2011
Quoted: 8 Post(s)
there's no coolant back there. it is more likely brake fluid.
2005 C230 kompressor sport, 6-speed manual
1982 Porsche 911 SC
schumicat is offline
post #3 of 10 (permalink) Old 10-18-2012, 03:37 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Or, if you have auto-ride-height, it could be hydraulic fluid.
In any event, if you are not competent to get in there and diagnose it, I would get it to a shop right away, and I'd be very careful about driving it there as well.
Good luck.
Check Codes is offline
post #4 of 10 (permalink) Old 10-18-2012, 03:57 PM Thread Starter
The fluid is green in color (thin water base not thick) and almost positive it is Coolant fluid.
Not exactly sure where its coming out of, possible coming from exhaust pipe however not positive.
p_rodan is offline
post #5 of 10 (permalink) Old 10-18-2012, 03:59 PM Thread Starter
I dont know if I have auto-ride-height. How can I tell?
p_rodan is offline
post #6 of 10 (permalink) Old 10-18-2012, 06:32 PM
Date registered: Aug 2009
Vehicle: 2005 C240 silver, 2008 R320CDI Cubanite
Quoted: 7 Post(s)
How long have you had this problem? is your coolant level going down? are you having any other problems? Even the exaust pipe is 2 feet further back. This is very odd. go under car to see where it is dripping from. Is it your car? maybe someone elses?
Perhaps as serious head gasket problem could cause enough coolant to leak into exhaust and get out the rear. but then that is a major problem!
If you cant figure it out, see your favorite independant MB garage asap
2005 C240 Silver
2008 R320CDI Cubanite Silver
efzauner is offline
post #7 of 10 (permalink) Old 10-18-2012, 07:16 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 532 Post(s)
You can tell you don't have auto-ride-height because you have a W203 - that was not an available option on your car.
If the coolant is coming from the exhaust pipe, then you do have a leaking head gasket.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #8 of 10 (permalink) Old 10-18-2012, 10:22 PM
Date registered: Apr 2009
What is your location,... MB coolant in North America is yellow,... not green,... unless you used non-MB (or non-OEM) coolant.
Look underneath,... where is the fluid dripping from? You should see a trail,... somewhere,...
It's possible that coolant is leaking from engine bay and then travelling along the topside of the bottom panels to get to the rear wheel,... are you parked on a slope?
If head gasket leak,... you should notice blu-ish white smoke from the tailpipe when engine is on.
sunnyray_toronto is offline
post #9 of 10 (permalink) Old 10-20-2012, 02:19 PM
Date registered: Dec 2011
check if you have a leaking cooland bottle inside the trunk
horacioamsler@hotmail.com is offline
post #10 of 10 (permalink) Old 10-20-2012, 03:58 PM
rudeney's Avatar
Quoted: 532 Post(s)
I would hope that the OP had already checked that, but still, it's a good point. Those large wells in the trunk are just the right size to store jugs of extra coolant.
- RODNEY
rudeney is offline
