Aftermarket Radio - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-25-2012, 10:28 AM Thread Starter
Date registered: Dec 2011
Aftermarket Radio
Hello,
I am currently looking to upgrade my Audio 20 on my W203 C180K Sport Edition. I have told that Mercedes does not have anything especially for W203 which would support BT, USB, SD Card etc. Is this correct? If i can't find anything from Mercedes which would be the best option for my car?
Thanks
ch215 is offline
post #2 of 4 (permalink) Old 03-25-2012, 12:50 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 579 Post(s)
Go with an aftermarket option. There are many great choices from the major electronics brands - Pioneer, Kenwood, etc. Your W203 can accommodate a double-DIN head unit. Make sure you don't have the Bose option. If not, then you can pretty much install what you want plug-and-play as wiring harness adapters and faceplates are readily available. If you do have Bose, that complicates things because there the speakers are special 2ohm models driven from a trunk-mounted amp. That amp is fed via fiber optic from the head unit. You have to replace the speakers, and then run wiring to bypass the Bose amp.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #3 of 4 (permalink) Old 03-26-2012, 06:56 AM
bnzmercedes1's Avatar
Date registered: Apr 2008
Vehicle: 2002 C320 wagon 1987 560sel 1997 E320
I had an aftermarket 7" in-dash pioneer system put in. He didn't have to replace the speakers, but it did cost a bit (aside from the stereo unit). I had the fiber optic system, the sub in the back is useless now.
Sent from my Autoguide iPhone app
bnzmercedes1 is offline
post #4 of 4 (permalink) Old 03-26-2012, 06:46 PM
rudeney's Avatar
Quoted: 579 Post(s)
All W203's have fiber optic - it's used for the CD changer, TeleAid and cell phone interfaces. But only if you have the optional Bose system does you car also use that fiber network to send audio output from the factory head unit to the Bose amp in the trunk. And in that case, it does not have any analog audio wiring in the dash.
To install an aftermarket system, the installer will have to run wires from the dash to the trunk where the Bose amp is then bypassed. If using the new head unit's built-in amp, then you run speaker-level wires and tie them directly to the speaker wires coming out of the Bose amp (disconnecting them from the Bose amp, of course). If using a new external amp, then most installers will put it in place of the Bose amp, and run low-level wire from the new head unit to the new amp in the trunk. The new amp's speaker outputs are tied then to the speaker output wiring from the removed Bose amp.
The problem with the Bose speakers is that they are 2ohm impedance which is usually not compatible with aftermarket systems; it will cause their amps to overheat and fail. Not only that, the Bose speakers generally sound terrible without using the proprietary equalization circuits built-in to their amp.
If you did not have the Bose system, then the amp was built-in to the factory radio head unit and there are high-level speaker level wires in the dash harness (direct wiring to the speakers). The factory speakers are fairly decent 4ohm models (although prone to dry rot). There are built-in bass blockers for the sail panel tweeters and bandpass filters for the door speakers, routing most of the bass to a passive subwoofer in the rear hat shelf.
In my kid's C240, I installed a Pioneer Avic 7010 model using it's built-in 25w x 4 amp to power the door speakers. Originally, that was the factory non-Bose speakers, and they sounded great, but dry rot won out. I replaced them with Pioneer mid-grade speakers and we really lost a lot of bass response compared to the factory models. So I added a 12" Pioneer subwoofer driven by a 500W RMS/1000w max Pyramid amp in the trunk. I had to run one low-level speaker wire from the head unit to the trunk to use the built-in subwoofer crossover of the Avic. It sounds great, and the kid is happy (though sometimes making too much boom-boom coming through the neighborhood). Total investment is still under $1,000.
- RODNEY
rudeney is offline
    Instrument Cluster and Radio/iPod not communicating, Radio stays on. ianhzl Audio & Telematics Forum 2 07-28-2011 02:14 PM
    2012 Scion xB Gets Standard Bluetooth and HD Radio, Pandora Internet Radio Optional AutoGuide.com AutoGuide.Com News 0 06-29-2011 07:10 AM
    Anyone upgrade the Stock radio to the Harmon Kardon Radio after delievery cigarlvr X204 GLK-Class 7 02-27-2011 12:48 PM
    RADIO RADIO RADIO know code but still no help to enjoy it PLEASE READ burbur W124 E,CE,D,TD Class 10 08-16-2008 10:54 PM
    Do they advertise the SLK on the radio? They are heavily pushing the Z3 in my local radio stations> Max R170 SLK-Class 7 07-02-2002 06:47 AM
