Side view mirror help! C240 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-08-2012, 12:47 PM Thread Starter
Date registered: May 2008
Somehow the glass on my drivers side view is loose from the motor (ok, I hit some bushes with it backing out of my driveway last summer). Anyone have some photos or know how to attach the mirror back to the motor so that I can slide the housing back on?
Thanks a ton.
Jebzino is offline
post #2 of 5 (permalink) Old 03-08-2012, 08:40 PM
Date registered: Mar 2010
Vehicle: 2002 C240
Attached are some instructions how to disassemble the mirror.
File Type: pdf AR88 Remove Outside Mirror Paneling.pdf (145.0 KB, 762 views)
File Type: pdf AR88 Remove Folding Drive for Outside Mirrors.pdf (177.3 KB, 561 views)
i5mast is offline
post #3 of 5 (permalink) Old 03-09-2012, 10:03 AM Thread Starter
Thanks but I still can't figure it out from those sheets. They don't show how the mirror comes off the motor or in my case goes back on.
Jebzino is offline
post #4 of 5 (permalink) Old 03-09-2012, 11:19 AM
Vehicle: 2002 C240
Take the mirror paneling off then compare it to the mirror on the passenger's side That's what I would do.
Edit: See this thread: http://www.benzworld.org/forums/w203...tallation.html
i5mast is offline
post #5 of 5 (permalink) Old 03-11-2012, 11:26 AM Thread Starter
Fixed! Basically did what you said and took the passenger side mirror housing off to look at it. There is a skinny metal wire like spring on the top part of the backside of the mirror this has to be pried upwards with a knife while holding the mirror in place onto the motor and the wire/spring needs to latch behind a very small plastic clip on top of the motor. Seems easy but was actually quite difficult.
Thanks for the help guys!
Jebzino is offline
    Rear view mirror and side mirror freak out! ccooper405 W140 S-Class 10 09-21-2016 08:17 AM
    Passenger Side SIgnal LAmp on side view mirror hockeystick W211 E-Class 6 12-20-2008 12:00 AM
    WANTED 1960 190D side view mirror - driver's side ed755 For Sale/Wanted/Trade/Giveaway 0 04-22-2005 06:54 PM
    Side view mirror glass for 2002 C240 mkwabena75 W203 C-Class 1 04-28-2004 04:41 PM
    side view mirror - c240 stan W203 C-Class 7 08-19-2002 09:37 PM
