Help! Ignition key won't turn - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-12-2012, 05:37 PM Thread Starter
Date registered: Sep 2011
I have a 2001 Mercedes c320 c-class. The ignition key won't turn, the lights don't turn on and I have use the metal key to unlock the door.Everything was working fine until today. Anyone know what could be wrong?
NextOne is offline
post #2 of 11 (permalink) Old 02-12-2012, 06:20 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 648 Post(s)
It's probably a dead vehicle battery.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #3 of 11 (permalink) Old 02-12-2012, 07:11 PM Thread Starter
I should be able to turn the ignition switch. If that was the case, should I?
NextOne is offline
post #4 of 11 (permalink) Old 02-12-2012, 08:14 PM
Date registered: Feb 2012
Vehicle: 2004 Mercedes-Benz E500
It does sound like a very dead battery. Without proper battery voltage most systems in the car will not respond to anything espically the ignition switch. Try checking the voltage of the battery and if low just charge it and hope for the best. Those model cars are notorious for amperage draws at rest which is why the battery is probably dead. Could be one or both your seat control units under the seats staying on draining your battery. I just speak from experience. Just an fyi.
ARODMBTECH is offline
post #5 of 11 (permalink) Old 02-13-2012, 05:43 PM
rudeney's Avatar
Quoted: 648 Post(s)
The ignition switch is not like the old key blade and tumbler systems of yesterday that were purely mechanical. MBZ uses a SmartKey system that validates an infrared code handshake to electronically unlock the ignition switch and enable the starter. The "turning" of the switch is just a throwback to the old blade systems; it could just as easily be a button. During that infrared handshake, the vehicle re-programs the random rolling code in the SmartKey fob. If that programming were to fail, it would permanently "toast" that key. To prevent that problem, the ignition switch system has logic in it so that if the vehicle battery is too low, it won;t even attempt the infrared handshake and thus the switch won't be unlocked. SO, yes, if you vehicle battery is dead or dying, you might not even be able to turn the key in the ignition switch.
- RODNEY
rudeney is offline
post #6 of 11 (permalink) Old 02-13-2012, 10:35 PM
post #7 of 11 (permalink) Old 01-07-2013, 07:01 PM
Date registered: Oct 2009
Guys, I'm having the same problem on my 05 E55. Key won't turn. Batteries in FOB are brand new from the store. I just gave the ignition LED and the FOB LED a good wipe down with rubbing alcohol. Car battery is at 14.5 volts (just tested with voltimeter). Car is all the way in park. So far I've tried moving the wheel back and forth, pressing the lock/unlock several times (both on the dash and FOB), and disconnecting the car battery. Don't know what's causing this.
More info: problem started happening after I parked the car for about two weeks without starting it. Don't know if that helps diagnosis.
Anyway, what gives? Anyone got any tips?!?! Trying to get this baby sold and something tells me nobody will buy it if they can't actually turn the key
Ahmed Mahad likes this.
kurtwz is offline
post #8 of 11 (permalink) Old 01-07-2013, 08:26 PM
Date registered: Jan 2011
Quoted: 8 Post(s)
I assume that voltage is with engine running. if not your voltmeter must be wrong (should be no more than 12.7 with engine off). do you have the second key that came with car?
2005 C230 kompressor sport, 6-speed manual
1982 Porsche 911 SC
schumicat is offline
post #9 of 11 (permalink) Old 01-07-2013, 08:29 PM
rudeney's Avatar
Quoted: 648 Post(s)
Battery voltage of 14.5 could be a problem - a "12 volt DC Lead Acid Battery" should put out around 12.7 volts max. Keep in mind the batteries in the SmartKey fob have nothing to do with starting the vehicle - they are only used for RCL (remote control locking). Also, do you have only one key? Have you tried another key?
- RODNEY
rudeney is offline
post #10 of 11 (permalink) Old 03-02-2015, 04:34 PM
Date registered: Mar 2015
My ignition, locks, lights, electric seats, windows, everything is locked up. Can't get the hood open to check or replace battery. Trying to get the hood open, the latch fell apart. How can I get the hood open? How can I get everything unlocked. Luckily the doors were unlocked.
Wanda C is offline
key won't turn ignition tt1968 C208/A208 CLK-Class 12 01-24-2017 01:42 PM
Ignition Key will not turn MRBSMITH W210 E-Class 5 04-11-2012 08:27 PM
Ignition Key Won't Turn MrGadget608 W210 E-Class 1 12-19-2011 10:22 PM
Key Won't Turn In Ignition Danii W140 S-Class 3 11-05-2011 04:19 PM
