C230 Water leak - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-25-2011, 06:36 AM Thread Starter
Date registered: Apr 2011
Vehicle: 2005 Mercedes Benz C230 Kompressor Sport
C230 Water leak
I noticed I have water leaking from the front left wheel well, right at the front tire guard. Its clear, clean water that is coming down. It has been doing it for a few days now, and I'm not entirely sure what it is. I thought it might just be the window washer leaking, but I'd be shocked if it held that much water (and water still comes out on the windshield). Any thoughts or ideas?
GreekMB is offline
post #2 of 4 (permalink) Old 04-25-2011, 04:58 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 668 Post(s)
Have you been running the A/C lately? It's likely just condensation from the evaporator coil.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is online now
post #3 of 4 (permalink) Old 04-26-2011, 11:25 AM
I've been getting a small puddle of water frequently coming from near the passenger's side tire, even on very dry days. I thought maybe it was coolant but after looking at it closely and sopping some up with a paper towel, it was definitely water. I don't use the air conditioner so I ruled out water from the AC.
Anyway I finally figured out where it was coming from. In the channel at the bottom of the windshield by the wipers, there are 4 weep holes that drain away water from the windshield. I poured some water in there and saw that 2 of the holes worked fine, but the other 2 were clogged. I used a foot long piece of weed whacker cord to fish down in there to open them. No more leak.
I think what was happening is that the water was slowly seeping through the clogs and out through the tubes that connected to those weep holes. My parking spot is under an oak tree so I'm guessing it got clogged with pollen.
imaref is offline
post #4 of 4 (permalink) Old 02-24-2015, 08:44 AM
Roger007's Avatar
Date registered: Sep 2004
Vehicle: C230SS,
Same is happening to me right now. Water leak from the driver's front engine bay by the front left wheel. Cleaned the car a week ago and didn't noticed any leaks until recently. The leak is water as I inspected it afew times this week. I'll check the drain plug holes on the leftside of the car ( W203 2005 C230 ) later on tonight when the wife gets home.
~Roger007
2005 C230 Kompressor
www.panerai.com
Roger007 is offline
Water leak red450SL General Mercedes-Benz 3 12-26-2009 08:11 AM
Water Leak gabemage W210 E-Class 10 04-16-2009 11:21 PM
WATER LEAK ? THE VIKING V-Class 2 02-19-2006 12:53 PM
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
New water leak! Benzonline W126 S,SE,SEC,SEL,SD,SDL Class 2 06-16-2005 01:23 PM
