Hot AND Cold Climate A/C Issue, Help! - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 04-12-2011, 12:53 PM Thread Starter
Date registered: Sep 2010
Hey guys, I got a weird issue with the Benz. It's a 2004 C230 Kompressor. When I turn the air on, with both climate temp knobs set to coldest, the driver side vents blow warm to hot-ish air, while the passenger side vents blow cold air.
I'm wondering if I need to recharge the freon, but the difference in temps on both sides has me thinking that is not the issue.
Any ideas on what's going on here? Thanks in advance!
mcglsr2 is offline
post #2 of 15 (permalink) Old 04-12-2011, 06:41 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Post
I'd start by placing a thermometer in the vents on the passenger side. If it reads 40 degrees F, or lower, freon should be OK and probably there is some air duct obstruction or with an air distribution failure. Of course, it can also be an electronic control failure.
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
post #3 of 15 (permalink) Old 04-12-2011, 07:38 PM
Arn560's Avatar
Vehicle: 04 C230 Kompressor
I agree with Joeval. Besides a shortage of freon (R-134a) would be warm air all round not just cold on one side. It seems as if one of the motorised dampers is stuck which is allowing the return air to be forced into the driver side supply duct. That, I don't know how to fix. I hope is it jammed & going over a bump works it loose then you're back in business!!!
Arn560 is offline
post #4 of 15 (permalink) Old 05-25-2011, 03:23 PM
realeyezsoul's Avatar
Date registered: Apr 2007
Vehicle: m5,acura rsx type,S and slk amg 230
did you ever resole this im having a problem like this but my passenger is the hot one.
To follow the path: Look to the master,
Follow the master, Walk with the master,
See through the master, Become the master.
"Place me in the company of those who seek Truth, but deliver me from those who believe to have found it."
realeyezsoul is offline
post #5 of 15 (permalink) Old 05-25-2011, 03:38 PM Thread Starter
No, I didn't. It went away by itself (for now, anyway). I suspect the issue is in the electronics that control the climate for each side. I don't think it's freon because the freon isn't split between drivers side and passenger side. Because the passenger side was cold, I think freon is fine. It seems more like the climate control on the drivers side, even though set to cold, was thinking it was set to warm. Thus warm air. At any rate, it sorted itself out, so I haven't bothered to look at it since. Fingers crossed for me it stays that way, and good luck to you - I hope yours sorts itself as well.
If it doesn't, and you figure out what's going on, please please update this thread so in the event it happens to me again I'll know what's going on
mcglsr2 is offline
post #6 of 15 (permalink) Old 07-07-2011, 04:08 PM
Date registered: Jun 2003
Vehicle: 2003 C230 coupe, 2008 ML320 CDI, 2013 C300 4matic
Anyone find a solution to this? My wife has a 2003 C230 Kompressor and now its ambient temp. air on driver's side and cold air on passenger side!!! Thanks.
JeffT is offline
post #7 of 15 (permalink) Old 07-07-2011, 07:40 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 670 Post(s)
Try a reset of the climate control system - press and hold both the recirculate and front defrost buttons until the lights start blinking. Release the buttons and wait a minute for the self-diagnostic test completes and the unit resets. This can sometimes help. If not, then it may be a broken control or stuck damper.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #8 of 15 (permalink) Old 07-08-2011, 10:32 AM
Date registered: Jul 2008
Vehicle: C200 Kompressor M111 2.0L Avantgarde Year 2002
Do flap syncro process as Mr.Rudeney say. If not fix, the flap linkage is broken or the servo motor is gone bad. Replace them the new good one.
W203 C200K M111 2002
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #9 of 15 (permalink) Old 07-13-2011, 07:19 AM
Date registered: Jul 2011
Vehicle: 2005 E500
If the vehicle is equipped with a duo-valve(heater core shut off valve) it would most likely be a suspect component if the passenger side is hot and drivers side is cold. In some cases both sides will blow hot. Clamp the inlet to the duo-valve and see what happens.
If the temperature progressively gets warmer from the right to the left. this is usually a sign of low charge levels.
211.070 is offline
post #10 of 15 (permalink) Old 07-22-2011, 08:35 AM Thread Starter
Thanks so much, I will give this a shot! By the way, it's back again.
I'm not sure if the vehicle is equipped with a duo-valve - meaning I don't know what that is so therefore don't know if the car has one or not However, the issue is the opposite of what you stated - the passenger side is COLD and the driver side is HOT. Does that then mean that it wouldn't be a duo-valve? We are taking the car in for Service B today, so I plan on asking them what they think - not to do any work on it, just see if they can shed some light on what the issue might be. Assuming the reset doesn't resolve it. I'll let you guys know what happens.
mcglsr2 is offline
500SL Climate Control - air too cold/too hot odara1 R129 SL-Class 6 06-24-2010 11:46 PM
Cold High Idle, Hot Hard start issue MBBoo R/C107 SL/SLC Class 27 07-29-2009 12:45 PM
hot and cold from climate control activ123 W210 E-Class 0 07-28-2006 09:31 PM
Climate problems blows hot and cold mgyl W210 E-Class 6 07-14-2005 12:50 AM
93' 300CE - Climate Control Not Blowing Hot nor Cold Air Guest (MBNZ) W124 E,CE,D,TD Class 5 05-15-2002 04:11 PM
