how do you disable alarm on a 2005 C240 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-19-2011, 09:56 AM Thread Starter
Date registered: Mar 2010
Hi,
I have a 2005 C240 and the alarm recently will go off for no reason. I read that it could be anything from a low battery, bad door sensor, or low alarm battery. The car starts up fine in the coldest weather and the alarm is loud and strong.
Personally, I don't want the alarm anyway and want to disable it. I read that on the 2003's, you can pull the #8 fuse in the engine compartment to do this.
My question is: is this the same for a 2005? Will anything else be disabled by pulling the fuse? Or is there a better way?
Thanks in advance.
mikeDinNYC is offline
post #2 of 5 (permalink) Old 02-20-2011, 03:55 PM
Date registered: Jan 2011
Quoted: 8 Post(s)
there is info about which fuse does what in the owner's manual and/or the sheet in the interior fuse compartment (see manual for how to access).
2005 C230 kompressor sport, 6-speed manual
1982 Porsche 911 SC
schumicat is offline
post #3 of 5 (permalink) Old 02-20-2011, 05:52 PM Thread Starter
yes, i got a hold of the fuse diagram and it states that the #8, #9 and #41 fuses all work with the alarm. i pulled the #8 fuse, which had been advised in a previous thread for a 2003, but now the remote locks don't work because they operate on the same #8 fuse.
post #4 of 5 (permalink) Old 02-21-2011, 09:11 AM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
The following is more work. However, this will have no negative effect on any other component in the car. Open the wheel well liner of the front passenger wheel and disconnect the connector for the alarm.
pcy is offline
post #5 of 5 (permalink) Old 02-21-2011, 01:01 PM
Quoted: 8 Post(s)
disconnecting the horn as suggested is probably the easiest way to deal with it. there are probably DIP switches somewhere which will lower the sensitivity of the glass breakage or motion sensor or disable door sensors, etc. but you would need to ask a dealer tech where to find them (no mention of alarm in the haynes manual). you would not want to lose the ignition lock feature of the system because unlike a noisy alarm, it actually prevents theft.
1982 Porsche 911 SC
    Is there a way to disable the alarm? jtoma878 C208/A208 CLK-Class 6 10-09-2015 04:42 PM
    Disable Alarm??? jervonics2112 W124 E,CE,D,TD Class 4 06-09-2010 03:11 AM
    alarm disable victoriajas W126 S,SE,SEC,SEL,SD,SDL Class 2 06-15-2007 06:08 PM
    can you disable the car alarm? greent2 W126 S,SE,SEC,SEL,SD,SDL Class 3 03-29-2007 02:59 AM
    How to disable alarm? KUYMAN C208/A208 CLK-Class 4 02-07-2002 12:07 AM
