suspension diagram - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 02-12-2011, 07:55 AM Thread Starter
Date registered: Feb 2011
Vehicle: 2002 MB C240,
suspension diagram
intersted in seeing a diagram identifying part name (control arm, thrust arm, etc..), if anyone could help. Thnx.
kalc240 is offline
post #2 of 8 (permalink) Old 02-12-2011, 09:30 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 383 Post(s)
I cannot see one WIS drawing that names all the parts for you. There are many drawings that cover different suspension/steering items. What are you mainly interested in?
Here is one that covers the torque strut, and the associated parts. However this part is also called (on other pages) tie strut and radius rod. So it gets confusing...
keyhole is offline
post #3 of 8 (permalink) Old 02-12-2011, 04:56 PM Thread Starter
Thank you for the diagram. I was told "thrust arm bushings" are old and worn and cracked and leaking "left control arm bushings". So i am interested in those two parts. It does get confusing with all the different names..
Thanks again for your help.
kalc240 is offline
post #4 of 8 (permalink) Old 02-13-2011, 06:19 AM
keyhole's Avatar
Quoted: 383 Post(s)
I did a bit more digging, and found this US site: Auto Parts - Parts.com, For Every Part of Your Life
If you enter your model/year, you can dig down to component areas, eg suspension. Then you can see a diagram with the parts named. They also give you a price.
I reckon that Items #1 and #6 are your upper/lower control arms - they have bushings that wear. Could your thrust arm be a tie rod #18? (also called link rod)
I'm not sure about the 'leaking' statement. Some engine mounts 'leak', as do shock absorbers, but I'm surprised about bushings..
Name:	C240 suspension.jpg
keyhole is offline
post #5 of 8 (permalink) Old 02-13-2011, 09:25 AM Thread Starter
Thrust arm vs. control arm?
Thanks Keyhole. I did have new sway bar links (#18 in diagram) installed recently at one shop and they told me everything else looked good. I went to another shop for transmission oil/filter service where they told me about the leaking bushings. I guess the thrust arm is an alternate name for Control arm. I am getting suspicious of this shop who also told me the v-belt is old and worn when it looks intact with no cracks and plenty of tread. I do plan to replace it though since it sounds easy to do and I don't know the last time it was replaced if ever with 87k on the odometer.
kalc240 is offline
post #6 of 8 (permalink) Old 02-14-2011, 08:31 PM
Date registered: Jan 2011
Quoted: 8 Post(s)
by "leaking" bushings he must mean something that is filled with grease, like a ball joint or tie rod end. they have rubber boots filled with grease to keep the moving parts lubricated. if the boot is torn the grease leaks out, the joint dries out and wears quickly and can seize up. parts 1 and 6 on the diagram look like they have such grease-filled boots. I think one is called the torque strut and the other the cross strut in the Hayes manual, and I htink they each have a ball joint at one end.
2005 C230 kompressor sport, 6-speed manual
1982 Porsche 911 SC
schumicat is offline
post #7 of 8 (permalink) Old 02-15-2011, 04:57 AM
keyhole's Avatar
Quoted: 383 Post(s)
+1 ^^
Now you mention it, I'm sure that you are right here about the bushings. I had overlooked that boot feature.
keyhole is offline
post #8 of 8 (permalink) Old 04-25-2011, 05:45 PM
Date registered: Dec 2009
Vehicle: 2002 C320
02 c320 leaking rear leaking bushing also?
I noticed a small pool of fluid in front of my rear wheel, silver dollar size, it appeared to be the constantcy of break fluid. I pulled the wheel and it looks like its coming from the area where the rear suspension mounts to the frame. It is definitely not coming from the breaks or leaky shock. I wonder if they put a bladder of sorts there for ride inprovement??? Does any one know of this?
Scott_of_Valencia is offline
  • Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    Front suspension diagram xman11 W203 C-Class 4 08-30-2013 09:08 AM
    anyone have suspension diagram clk500 felixy1018 C209/A209 CLK-Class 14 01-10-2011 05:08 PM
    E55 Suspension Diagram uluna W211 E55 AMG, E63 AMG 4 01-09-2008 06:14 PM
    Diagram for the Self-leveling suspension sklas W126 S,SE,SEC,SEL,SD,SDL Class 0 08-19-2007 10:41 AM
    I need help finding a diagram of a suspension...... Guest (MBNZ) General Mercedes-Benz 1 12-23-2001 04:16 PM
