2006 c230 Shift Knob Removal - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-04-2010, 03:42 PM Thread Starter
white124's Avatar
Date registered: Oct 2009
Vehicle: 2003 ML500, 2009 Smart
Post 2006 c230 Shift Knob Removal
Does anyone know how to remove the shift knob? Mine has all of the chrome flaking off at the top and I wanted to either replace or try repainting it. Does it screw off or do you have to remove the boot? Thanks in advance for any help.
white124 is offline
post #2 of 3 (permalink) Old 08-23-2014, 11:16 AM
Date registered: Dec 2013
Vehicle: 2006 C230 Sport
BUMP
I have the same problem. Automatic. Here is a picture of mine.
superuo is offline
post #3 of 3 (permalink) Old 08-23-2014, 05:50 PM
I got it figured out. You have to lift up the entire silver console panel, then just under the boot there is a small plastic collar, you turn that one quarter turn counter clockwise then it drops down. You can then see there are 4 plastic prongs holding the entire shifter knob assembly onto the shifter itself and all you have to do at this point is simply pull up on the shifter knob, with some serious force I might add, until it comes right off.
I suggest you have the gear in neutral because you do not want to hit your hand on the radio or dash.
I am doing a video on how to do this fix and I will post a link for it here when I get it finished.
superuo is offline
    Shift Knob Removal Help ! GODZILLA W140 S-Class 8 07-06-2008 09:27 PM
    Shift Knob Removal hamsanwich81 W116 S, SE, SEL, SD Class 4 06-03-2006 11:36 PM
    shift knob removal shmelvin W140 S-Class 7 05-29-2004 12:41 PM
    shift knob removal PrinceGeorges W126 S,SE,SEC,SEL,SD,SDL Class 2 04-30-2003 07:05 AM
    Shift knob Removal... MikeT W163 M-Class 41 12-12-2001 06:43 PM
