CD Changer replacement - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-13-2010, 02:53 PM Thread Starter
Date registered: Aug 2010
Vehicle: 2001 c320, 1994 e320, 1988 300ce, 1980 230e, 1978 240d, 1988 BMW 635csi
So my problem is this. I pulled out the 6 disc changer on my 2001 c320 (MC3010 unit) to fix the "no cd found error". While fixing I accidently severed the ribbon for the power and optics. Now I have no power at all on the stereo. Is this due to the fact that the CD changer is disconnected....I purchased a new one but haven't gotten it yet, but I don't know if this will solve the issue or not. Please help
dubkash is offline
post #2 of 9 (permalink) Old 09-14-2010, 10:01 AM Thread Starter
If anyone runs into this issue, the solution is as follows. You have to pull out the HU and behind there is a fuse. Mine was bad so I replaced as wah-lah HU working again. If anyone needs instructions on removing the HU please let me know and I can send instructions and pictures.
dubkash is offline
post #3 of 9 (permalink) Old 09-14-2010, 10:34 AM
Date registered: Jan 2010
I have the same problem; "no cd found". yes, please; I'd appreciate instructions and pics. Dumb question. What is HU?
jacktpr is offline
post #4 of 9 (permalink) Old 09-14-2010, 10:45 AM Thread Starter
This link is how to fix the cd changer. I am assuming your changer is in the glove box?
Miko's Blogs: CD Changer Repair
It is actually pretty easy, just make VERY sure not to sever or crimp the ribbon as I did otherwise you will be buying yourself a new changer. It is hard to tell from the pictures but the piece you need to adjust is on the bottom side of the changer once you have it open.
HU is head unit. The radio/nav unit. Make sure you turn the power off on this unit before removing the cd changer or you risk burning the fuse out and that is a whole different project which I succesfully tackled so if that happens, let me know and I can help with that as well.
Good luck.
dubkash is offline
post #5 of 9 (permalink) Old 09-17-2010, 08:29 PM
Thanks Dubkash! Actually the cd changer is in the trunk; hope to have some time this weekend to review the document and look further into this.
jacktpr is offline
post #6 of 9 (permalink) Old 09-18-2010, 09:17 AM Thread Starter
Should be fairly similar. What car do you have?
dubkash is offline
post #7 of 9 (permalink) Old 09-19-2010, 02:47 PM
Date registered: Dec 2009
Vehicle: 2002 SLK230
Hope you can help. I have a 2002 SLK 230 with a factory installed CD changer in the trunk. Radio unit does not recognize that the changer is attached. Dealership checked cables. Cables are good but they want $700+ to replace changer. I think it is a fuse, but if not it is a good place to start and surely won't cost $700. How do I replace the fuse in the CD changer in the trunk?
SuKo230 is offline
post #8 of 9 (permalink) Old 09-20-2010, 09:14 AM Thread Starter
Do you have a fuse diagram? If you do check it and see if there is even a fuse for the changer (I am not familiar with the SLK set up). Given the multiple issues that the cd changers seem to have, I would tend to think that if the changer is bad then replacement or repair is your best option. Is your radio working with sound?
Give these guys a call and they can go over your options
Same Day Auto Audio Repair Service Inc.
1228 South Military HWY. Suite F
Chesapeake VA, 23320
(757)420-5206 office
(757)420-5582 fax
(757)277-1080 cell
dubkash is offline
post #9 of 9 (permalink) Old 09-20-2010, 09:47 AM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
You can buy used CD changers for around $100 to $200 on e-bay.
New OEM CD changers are around $200 - $300 on ebay.
pcy is offline
    CD Changer replacement dubkash W203 C-Class 2 09-10-2010 07:46 PM
    CD Changer replacement dubkash General Mercedes-Benz 0 09-10-2010 09:35 AM
    Need Help: CD Changer install (No Changer message after installing changer) az2md W210 E-Class 14 08-10-2006 06:53 AM
    CD Changer replacement steves R170 SLK-Class 1 06-07-2005 02:56 PM
    Car radio question: Is IP-bus changer control compatable with the stock CD changer in the trunk? DaveS R170 SLK-Class 1 04-04-2004 12:52 PM
