NEED HELP Fault code P200A - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-10-2010, 01:19 PM Thread Starter
Date registered: Aug 2007
Hi,
I am new to this but i need help.
I have 2003 C230 Kompresor Sedan Manual Transmision 6 speed.
I have had the car for 5 years and no problems and just recently it would not start. Mechanic replaced the Crank sensor and the Fuel pomp.It works.
Check engine still on and it reads code
P200A-02 (Throttle valve actuator) Actual value potentiometer.Position Emegency running.
It drives but when i am swiching gears and acelerating it feals like it is missfiring for 1/2 second and it works fine after that and it does it again and again.some times it does it multiple times and some times it does it only 1 or 2 throught the drive.
armandi21 is offline
post #2 of 2 (permalink) Old 08-10-2010, 05:27 PM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
try resetting the Throttle. Try searching with words 'throttle reset'
pcy is offline
Fault Code #19 chtaylor W124 E,CE,D,TD Class 3 06-11-2012 07:21 PM
Fault Code 13 (ETC) What is it? The Melmaan W124 E,CE,D,TD Class 5 03-06-2008 09:55 AM
60% fault code bruiserbruce W126 S,SE,SEC,SEL,SD,SDL Class 11 05-25-2007 05:44 AM
fault code rufflesurf V-Class 2 03-27-2007 06:08 AM
Help with Fault Code Please Eiknujzneb W124 E,CE,D,TD Class 9 07-24-2004 08:37 AM
