Lifting car with floor jack. Bests points for jack and stands? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-18-2010, 04:54 AM Thread Starter
Date registered: Mar 2009
I couldnt find anything about jacking up the car in the manual except talking about the mini jack that comes with the car. I'll be using a jack and jack stands. What are the best places to put them? Thanks
2006 Mercedes C230 Sport
2004 BMW X3
2001 Mustang GT Convertible
DirtyD is offline
post #2 of 7 (permalink) Old 07-18-2010, 06:43 AM
Date registered: Dec 2009
My C280 has four jack points on the frame. They are below each of the four doors and seem to be made of hard rubber.
mdbenzgirl is offline
post #3 of 7 (permalink) Old 07-18-2010, 06:51 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
Yes - but they are for wheel changing, etc. You cannot put a jackstand there!
keyhole is offline
post #4 of 7 (permalink) Old 07-19-2010, 04:54 AM Thread Starter
bump
2004 BMW X3
DirtyD is offline
post #5 of 7 (permalink) Old 07-19-2010, 08:07 AM
keyhole's Avatar
Quoted: 381 Post(s)
DD
The WIS does not advise where to put axle stands (it is the M-B workshop document after all, where lifts are available)
However, it does advise where to lift from. Your W203 has the same chassis as my W209 CLK, so I am familiar with this image below.
If you remove the plastic covers under your car, you will see the 'block' at the centre of the front cross transverse of the front axle. I would use a block of wood to protect the surface while jacking.
At the rear, MB suggest raising the bottom of the diff. box. Again, I would protect the surface with a block of wood.
The axle stands can then fit under the axles - not the steering gear, of course.
keyhole is offline
post #6 of 7 (permalink) Old 07-19-2010, 09:22 AM
Date registered: Jan 2010
if your not needing to raise the rear why dont you use ramps?
jster611 is offline
post #7 of 7 (permalink) Old 07-19-2010, 10:22 AM Thread Starter
Originally Posted by keyhole View Post
DD
Thanks
2004 BMW X3
DirtyD is offline
    Lifting a 406 with a floor jack under the differential a bad idea? MegaMog Unimog 14 01-06-2010 09:47 AM
    Using Floor Jack and Jack Stands Mashcigar W210 E-Class 6 01-08-2007 10:25 PM
    Floor Jack Points larryk R170 SLK-Class 3 07-09-2005 07:54 AM
    How To: 1 Way To Use a Floor Jack and Jack Stands + Photos slk55er R171 SLK-Class 2 03-11-2005 06:07 AM
    Where do I place a floor jack and jack stands? jcochrane007 W124 E,CE,D,TD Class 1 05-20-2003 05:02 PM
