Check transmission fluid? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 06-22-2010, 07:12 AM Thread Starter
Date registered: Sep 2005
Vehicle: 2002 C240
Just bought a 2002 C240 w/ 100k miles, Is there anyway to check the transmission fluid? I asked the seller if he had changed it recently and it was a guy who had basically never opened the hood and just took it to the mercedes dealer when the computer said it needed service. According to the manual it doesnt need to be changed and thus they dont have a dip stick? but, I have been reading otherwise on this forum
nokkieny is offline
post #2 of 12 (permalink) Old 06-22-2010, 01:29 PM
ontmiss's Avatar
Date registered: Apr 2010
Vehicle: 2007 C280 4Matic Avantgarde
A specially graduated 'measuring stick' can be purchased from MB parts desk, with a chart specific for the level of each gearbox.The ATF level is checked with the car level and the engine running, and already warmed up to 80 deg °C. This can be checked by use of an IR digital thermometer with the laser light aimed at the auto gearbox sump under the car. The level is critical, so the temperature check is essential.
ID:	315490   Click image for larger version
ID:	315491   Click image for larger version
ontmiss is offline
post #3 of 12 (permalink) Old 06-22-2010, 02:09 PM
sd300td's Avatar
Date registered: Dec 2008
Quoted: 10 Post(s)
I would have it drained and filled since you don't know if it's been done yet. Every 60K miles.
2005 230 K, 26k-77k (sold)
1982 300 TD, 167k-226k
1982 240 D, 308k-327k (sold)
1998 E 320, 120K-141K
sd300td is offline
post #4 of 12 (permalink) Old 06-22-2010, 02:52 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If he only did what MB required then I'm with the other post, CHANGE IT NOW.
If you don't want to DIY that's fine but get it done. It's expensive since the fluid is costly ($15/L) but cheaper than a replacement transmission.
There is an excellent FAQ on this 722.6xx transmission in the W210 stickies if you want to learn lots about it, read through the FAQ.
Check Codes is offline
post #5 of 12 (permalink) Old 06-22-2010, 05:52 PM
sd300td's Avatar
Quoted: 10 Post(s)
Fluid is probably close to a $100. I forget what I paid for a new filter, but it was probably 30 to 50 bucks. If you pay a mechanic plan on spending between 1/2 and 1 hour of labor. Regardless, shouldn't cost you more than $200 at a good indy mechanic.
sd300td is offline
post #6 of 12 (permalink) Old 06-23-2010, 06:07 AM Thread Starter
Vehicle: 2002 C240
Okay, I get it changed for sure, any other things that would have been over looked by mercedes that probably need to be done?
nokkieny is offline
post #7 of 12 (permalink) Old 06-23-2010, 08:02 AM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 604 Post(s)
While you are getting the tranmission serviced, you might as well have the mechanic replace the seal on the TCU connector. If it's not leaking now, it will. It shouldn't add more than about $50 to the job. Also, make sure you don't have the bad Valeo radiator. If so, have it repalced as they are known to fail and dump coolant into the transmission fluid.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #8 of 12 (permalink) Old 06-24-2010, 07:07 AM Thread Starter
Vehicle: 2002 C240
I found this from another post:
FAULTY RADIATOR COOLER TANKS
Causes tranmission failure
According to Mercedes Benz Star Bulletin #P-B 27.55/50f, dated March 24, 2006, there is a problem with Valeo radiators up to production date 9/2003 installed in models:
203.040/061/064/065/081/084/261/264/281/284/740/747/746 also
How do which 203.xxx my car is?
nokkieny is offline
post #9 of 12 (permalink) Old 06-24-2010, 08:25 AM
ontmiss's Avatar
send me a VIN number, i'll find out
ontmiss is offline
post #10 of 12 (permalink) Old 06-24-2010, 01:41 PM
Date registered: Oct 2009
Vehicle: 2004 C230K
Good timing with this.
I recently went to the dealer to have them flush my tranny fluid due to it acting funny and starting to have hard shifts.. They ran tests and found coolant in the trans fluid due to the radiator..
I called Mercedes, the dealer, and where I purchased the car and I'm getting no assistance at all.. They said it will be out of pocket for me.
Anyone else run into this problem and get it fixed by MB for no cost?
You would think since they acknowledged it they'd do something about it
dymmeh is offline
    How to check transmission fluid? Owsley9 W123 E,CE,D,CD,TD,TE Class 8 08-14-2009 07:09 AM
    Transmission fluid check snakoiler C208/A208 CLK-Class 17 06-15-2009 12:29 PM
    How to check transmission fluid? cjstanford C209/A209 CLK-Class 5 03-25-2008 05:58 PM
    How do you check the transmission fluid? fredrice R170 SLK-Class 5 01-22-2004 01:34 PM
    How to check transmission fluid ScubaDriver W163 M-Class 9 05-20-2003 09:55 AM
