C320 2003 Key does not work Help! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-20-2010, 12:47 PM Thread Starter
Date registered: Jan 2010
My keyless key will not start my car, the buttons work to unlock the doors ect...
but it will not turn in the ignition.
Every dealer I talk to has a different story, is there a way I can reprogram this myself.
Any help is appreciated
Thanks
pjoseph is offline
post #2 of 4 (permalink) Old 05-20-2010, 01:55 PM
Date registered: May 2009
There could be a couple of things, but it could also be something very simple. this has happened to me, my car was park at a decline with the tires turned all the way left.
when you put in your key, does it make that grinding noise that it normally does ???
if not, it is just as if your steering wheel is locked... what i did was insert the key, unload my parking brake, and since my car was standard i let the car slide a little. turned the steering wheel a little bit and the grinding noise came meaning that the key has been recognized.
let me know if that works.
atiqraza is offline
post #3 of 4 (permalink) Old 05-20-2010, 04:59 PM Thread Starter
thanks for the reply
I decided to change the batteries and now the car starts. they should have some kind of key start as a backup. For some reason now the car does not open when you hit the unlock button but all others work, I am happy the car starts at this point.
thanks
pjoseph is offline
post #4 of 4 (permalink) Old 05-20-2010, 07:26 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 532 Post(s)
The battery in the Smartkey has nothing to do with the key's ability to start the engine. There is an indutive coil inside the ignition switch that powers the key for starting. The battery is only for the remote control functions. Something else was wrong here. Like Agra's asked, did you here the usual mechanical "grinding" noise when inserting the key in the ignition switch? If so, that means that the Drive Authorization System validated the key. From there, the inability to rotate the ignition switch is purely a mechanical problem. If there was no noise, then DAS did not recognize the key and again, that's not an issue with the battery in the fob.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
    2003 c320 4matic conradf W203 C-Class 4 08-22-2010 09:08 PM
    C320 Key/Ignition Problem Turbo6 W203 C-Class 12 01-22-2009 07:14 AM
    2001 c320 doesn't recognize smart key scorpnaz7 W203 C-Class 12 11-14-2007 06:54 PM
    "B" Service for 2003 C320 N1ML W203 C-Class 1 02-11-2006 08:57 AM
    questions about 2003 C320...please help pz420 W203 C-Class 3 07-29-2005 11:21 PM
