2002 C240 Change Transmission Fluid? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 05-18-2010, 07:13 PM Thread Starter
Date registered: Jan 2010
Hi All,
I'm really confused about whether I should change my auto transmission fluid. I just got this car and it runs great; from what I can tell, it has never had transmissiion service. I just passed 100,000 miles and I am preparing to have maint done for an oil change and the 100,000 mile maint. of changing the spark plugs. I have read/heard conflicting stories about the transmission fluid; some say, at 100,000 miles and it never being changed, it's better NOT to change the fluid and in fact it could cause damage. Others say change it. I'ld love to hear opinions from you guys.
thanks!
jacktpr is offline
post #2 of 10 (permalink) Old 05-18-2010, 07:51 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 670 Post(s)
There is some validity to the arguments against changing fluid that's been in the transmission a long time, but I'd say they do not apply to MBZ's. First of all, MBZ uses full synthetic fluid which does not break down like conventional oils. Second, the fluid change will replace less than half of the total capacity. Finally, you will be changing the filter and that is always a good thing. If it were my car, I'd do it.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #3 of 10 (permalink) Old 05-19-2010, 07:03 AM
Andrzejek's Avatar
Date registered: Jul 2004
Vehicle: 00 C-230, 04 C-240
If you don't change the tranny fluid, you might be OK for another 30 to 40K miles before "passing the point of no return". If you do change it right now, there is a slight chance that you will run into problems, such as a plugged high pressure solenoid, but it's fixable RIGHT NOW. If you wait, than it will be a new tranny in your basket -- around $5K for a rebuilt/installed.
I would not wait much longer, and have it serviced every 30K from now on. More often if you are in a hot climate.
Andrzejek is offline
post #4 of 10 (permalink) Old 05-19-2010, 05:14 PM Thread Starter
Thanks for the feedback; I was talking to someone today and they said a change would be ok, but not flush of the fluid. Thanks again for the insight
jacktpr is offline
post #5 of 10 (permalink) Old 05-23-2010, 05:45 PM
Vehicle: w124 400E x R129 w210
Quoted: 21 Post(s)
"...change it but don't flush it..." olde wifes tales. That fluid could have used a change at 50,000, synthetic or not. Change it yourself ( ALSO EMPTY TORQUE CONVERTER AND REPLACE FILTER....easy but messy) or spend the money and have it flushed....but...DO IT NOW!!!...It's overdue. Mercedes idea of "lifetime" fluid is the lifetime of the warranty. After that they don't give'a...so do it.
Brian McL is offline
post #6 of 10 (permalink) Old 05-25-2010, 05:57 PM
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup and 2006 ML350
Quoted: 13 Post(s)
Do it. Full Flush.
Read and know all.
C230 Sport Coup's All things AT Transmission related
Do the orings while you are at.
Check installuniversity.com
2006 ML350 - Stock
2002 C7 Evolution Orion Blue 2.3L C230 Coupe
Auto-Pano-Oyster Leather-Audio 10
AMG Front bar 22mm-17" Wheels- C32 Brakes- H&R 19mm rear sway
TEIN SS Coilovers -
Clear sides- 2005 tails, Blinkers & Grill- Tinted Windows
Bi-Xenons-Clear Fogs- Clear Side/Stealth Bulbs
C230 Sport Coup is offline
post #7 of 10 (permalink) Old 05-26-2010, 12:20 PM
redwood's Avatar
Vehicle: 500E, E320, 190E, E55
Quoted: 13 Post(s)
definitely DO change your original fluid and filter. Use ONLY the OEM Mercedes (febi bilstein) fluid. Approx 4.5 Liters for just pan. after that you can leave it alone for the next 40K miles (official interval is 39K from MBZ)
Redwood
E320 3.2 W211
E55 5.5 W211
500E 5.0 W124
190E 2.3 W201
redwood is offline
post #8 of 10 (permalink) Old 05-27-2010, 12:55 PM
Date registered: Mar 2008
Vehicle: 1995 325IC and 1986 560SL
Send a message via MSN to ttnguyen23
Originally Posted by jacktpr View Post
Hi All,
thanks!
For your information I did my tranmisssion fluid change and new filter and gasket change on my 2005 C230 Kompressor last week. The car is only 77,000 miles I notice the fluid is dirty and when I took the filter off I can see a dark black fuid comes out. Also when I clean the pan in the bottom is heavy dard fluid.
I am not the expert but I do not beleive what I see how dirty the fluid and I can confirm no fluid is life time. I will replace every 30,000 miles from now on.
I think the job is not bad and the cost around $80 ( 4 litters and afilter and a gasket).
The only I can not find the drain for the converter so I did not do the convertier.
ttnguyen23 is offline
post #9 of 10 (permalink) Old 09-18-2010, 01:54 PM Thread Starter
Thanks all, for the advice. I did end up changing it last Saturday and it seems fine. IF there was a problem, would it appear immediately? It seems to be running fine. I bought Mercdes parts and had a mercedes mechanic do it for me
jacktpr is offline
post #10 of 10 (permalink) Old 09-19-2010, 07:26 PM
rudeney's Avatar
Quoted: 670 Post(s)
Problems would likely take a while to surface, but I'd bet yours is going to be just fine.
- RODNEY
rudeney is offline
To change or Not to change? -- That is the ML320 transmission fluid question!! ebrington W163 M-Class 14 03-20-2011 03:17 PM
When to Change oil in 2002 C240 Juicy29 General Mercedes-Benz 4 08-18-2008 05:57 PM
HELP! C240 03NO Gear After Transmission Fluid Change zebra100 W203 C-Class 3 05-27-2008 02:08 PM
C240 Manual Transmission Oil Fluid jim628 W203 C-Class 0 07-02-2007 12:15 AM
How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 11 08-17-2006 04:31 PM
