2002 C240 No Heat - *Solved* - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-04-2010, 08:59 PM Thread Starter
Date registered: Mar 2010
Vehicle: C240 Sedan
This is my first post here. I am very thankful that I found this web site.
I bought a used C240 from a friend of mine in LA. I flew out to LA from Columbus, Ohio and drove it back. While in LA, I had a new aftermarket head unit installed. Halfway through Arizona on the drive back, I realized I had no heat in the car and that I couldn't seem to get the cold air to stop coming from near my feet.
I Googled here via my laptop while at a rest area and found this site and a thread with someone mentioning similar symptoms after getting a car stereo installed.
I ended up having to drive all the way to Columbus with no heat and then taking it in and having it looked at earlier this evening.
Turns out, the post on here from the guy with similar symptoms as mine was correct. The install guy had missed replacing one of the connections on the climate control.
I was really worried that it was something serious that needed replaced or was defective.
Long story short, my heat works and I'm really enjoying my C240.
I hope to frequent these forums often.
Many, many thanks for providing a valuable resource.
Best,
Michael
mcseufer is offline
post #2 of 3 (permalink) Old 03-04-2010, 11:48 PM
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
Glad you got it sorted out, and it wasn't an expensive fix... Welcome to the forum!
2002 C32 AMG Sedan [111,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | LET 185MM & ECU | TVT Thermostat | PSK Belt Wrap | CM30
DIY Intercooler Isolation | 26x7x2 FB H/E | Intercooler Reservoir | Battery Relocation | Lorinser Sides
2002c230 is offline
post #3 of 3 (permalink) Old 03-06-2010, 06:33 AM
Date registered: Jul 2009
Vehicle: MB 2002 C240
Exact same thing happened to me after I had an Alpine deck installed.
caribbeankid92 is offline
2002 c240 blasts heat (quick question) c.stingel W203 C-Class 0 05-25-2009 06:55 PM
Prairie Winters 0 B200T 1 - Heat Problem Finally Solved prairiebenz W245 B-Class 16 01-29-2009 07:56 AM
2002 C240 Brakelight vs 2003 C240 Brakelight r0bert0e W203 C-Class 2 06-25-2007 02:56 PM
Eibach Springs from 2002 C230 Coupe > Can I use it on my 2002 C240 AMG702 W203 C-Class 1 08-29-2004 09:12 AM
2001 C240 HEATER FLOOR HEAT MAX BLAKELY W203 C-Class 0 02-20-2004 05:29 PM
