HELP!! Need help changing the bulb on my left rear brake light? Any suggestions?? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-18-2010, 05:51 AM Thread Starter
Date registered: Feb 2010
Question HELP!! Need help changing the bulb on my left rear brake light? Any suggestions??
Need help changing the left rear brake light bulb! My sensor came on a few days ago and the dealer wants to charge over $35 to change it out when the part is just $2.60???? I figure this shouldn't be too difficult.... Would seriously appreciate any help out there....
RealtorMaria is offline
post #2 of 4 (permalink) Old 02-18-2010, 04:38 PM
CC&FABB's Avatar
Date registered: Jan 2010
Vehicle: 2004 C230 Kompressor
on my 04 C230 all you do is take the carpet over off from in front of the brakes lights then take the plastic cover off in front of the tail light and all the bulbs are exposed. Then just change the bulb that needs to be replaced....
CC&FABB is offline
post #3 of 4 (permalink) Old 02-18-2010, 05:44 PM
Vehicle: 2004 C230 Kompressor Sport Coupe
You could help us be more precise by telling the year and model.
It is also in your owner's manual, with pictures. Page 291 on the 2003 manual. There's lots of useful information in there so it's worth at least skimming through. You might find hidden features as well.
zeet is offline
post #4 of 4 (permalink) Old 02-20-2010, 08:54 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 579 Post(s)
My advice would be to change all the bulbs at once. Often, when one bulb goes, the others aren't far behind. I chased bad bulbs that would set off the sensor and display an error on the instrument cluster for months until I finally just replaced them all.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is online now
    Left rear brake light malfunction Raylee177 W210 E-Class 10 01-03-2009 11:56 PM
    Changing Blown Brake Light Bulb jamesman W163 M-Class 12 04-15-2008 06:10 PM
    left rear brake light stuck on? corvetteZ06 W163 M-Class 2 12-12-2006 11:43 AM
    Left rear stop light bulb ok but it won't light. Lenny R170 SLK-Class 6 10-09-2001 02:03 AM
    Left rear stop light bulb ok but it won't light. Lenny R170 SLK-Class 2 10-08-2001 09:48 AM
