Cant open hood on 2007 C230 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-18-2009, 10:45 AM Thread Starter
Date registered: Apr 2008
Vehicle: 2007 C230 Sport (RWD)
Hello,
My original post in the car care section was about storing the car for winter, but now I have anothe problem.
The hood latch (pops out of the front grill) broke and came off from my 2007 C230. The hood comes up about half an inch but will not open all the way, since I do not have a latch to pull on. Tried to unlatch by putting fingers through the grill but did not work. Does anyone know the exact art of opening the hood when the latch is broken? Also, is it fairly easy to install a new latch once I get the hood open? I'd hate to take it to the dealer (well the battery is dead so, can't even drive it. need to open the hood for a jump).
Any advise will be appreciated...
Thanks....
thareek is offline
post #2 of 5 (permalink) Old 12-18-2009, 11:02 AM
rjb190e's Avatar
Date registered: Apr 2006
Vehicle: 2.3-16 | A3 2.0T | 986 Boxster
Quoted: 14 Post(s)
Send a message via AIM to rjb190e Send a message via Yahoo to rjb190e
I had luck with needle nose pliers when I broke the same part on my 190 several years ago. Fish them in there and start pulling on what's left of the latch.
rjb190e is offline
post #3 of 5 (permalink) Old 12-18-2009, 12:23 PM
Vehicle: 2004 C230 Kompressor Sport Coupe
The latch is easy to replace. It is held on with a simple circlip, and the part is cheap. My coupe had a broken one when I bought it, the first thing I fixed. Look under the edge of the hood, it is possible to open it without the handle, I promise.
zeet is offline
post #4 of 5 (permalink) Old 11-10-2016, 12:55 PM
Date registered: May 2010
Vehicle: 2005 C230 White Coupe
I had this problem as well on a 2005 C230.
First off, whatever you do (as suggested elsewhere here) do not pull the interior hood release as far as it can go! I broke mine, made the repair worse, and now have to buy ($12) & install another interior hood release. With the interior hood release broken I used a pair of pliers to pull on the end latch wire in the exact travel direction of the broken latch (horizontal, not up or down). That opened the hood.
After playing with the hood safety latch numerous times I just could not find out what was sticking. A Southern California car rust wasn't the culprit. I had read about other owners breaking their grill or sawing hood just to get to the hood safety latch release. My car needed oil so I had to get the hood open. I thought this is really gonna take some time & money!
But then I decided to reproach the fix an easier way, I WD40 It! I sprayed it thoroughly through the small hood opening and guess what, It opened on the very first time I tried. Once opened, I sprayed the safety latch and the hood release mechanisms. Don't wanna go through this ever again! I hope this simple fix helps someone.
ALBEE is offline
post #5 of 5 (permalink) Old 11-10-2016, 07:17 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 664 Post(s)
If the cable is broken, you'll need to lift the car, remove the front wheels, then remove the fender liners and gain access to the latches where you can manually disengage them.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is online now
Hood Release Cable Broke...Can't Open Hood..Help! NRMl430 W163 M-Class 53 03-19-2015 08:41 AM
Hood release broke! how do i open my hood now??? Benznoob26 W201 190-Class 4 09-28-2009 07:08 PM
Ok so how do I open the hood? ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 32 06-19-2008 10:07 PM
FS: 2007 C230 Grille and Hood star RJc230 For Sale/Wanted/Trade/Giveaway 0 03-16-2007 09:14 AM
hood won't open help ! kmichael30 W123 E,CE,D,CD,TD,TE Class 3 10-31-2004 07:04 AM
