» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 11-13-2009, 06:32 PM   #1 (permalink)
Rusty Axle's Avatar
Date registered: Nov 2008
Vehicle: 2007 C230 Sport
A/C Condensor Drain Tube Location
The A/C smells like "toe" again, and I've sprayed Lysol into the under hood intake on multiple occasions. Seems like the odor comes back pretty quickly. It just occurred to me that I never saw any drops of water on the driveway this summer when the A/C was running, so I suspect a plugged drain tube. Since I live in Houston, I would expect to see some evidence of the de-humidification that occurs when 98% humidity meets a cold A/C condensor.
I jacked the car up on the passenger side jack point (and put a jack stand under a front suspension component) and tried to find the drain tube so that I could run a wire up it to make sure it is open. But with the car sitting so low to begin with and all the plastic underbody panels, I couldn't find the tube, which I would guess is in the firewall area on the passenger side. Anyone know exactly where it is?
Also, how much work is it to expose the A/C condensor for cleaning? It's located under the dash on the passenger side, right?
Rusty Axle is offline   Reply With Quote
A/C Drain Tube edwardgwright W126 S,SE,SEC,SEL,SD,SDL Class 2 05-27-2008 03:04 AM
sunroof drain tube 2000ml320 W163 M-Class 2 04-14-2007 06:05 PM
A/C drain tube ('98 C230) Pawsh W202 C-Class 0 05-21-2004 10:01 AM
Condensor leaking, another 1100$ down the drain :-( johan6504 W124 E,CE,D,TD Class 1 03-20-2003 07:41 AM
Anyone use that new Fram drain tube gizmo yet? PaulZ W163 M-Class 7 05-02-2002 04:09 PM
