c240 722.6 transmission no forward and reverse
19K views 5 replies 3 participants last post by  hardball1957
#1 · (Edited)
Man you would not believe after changing ATF fluid and removing the valve body and installing Sonax control overlap valve sleeves I now have no forward or reverse like its in neutral all the time.
I have checked the linkage and its connected and moving.
I am hoping someone can help with potential causes.
Does anyone have any ideas?
Thanks
#3 ·
response to Andrzejek
Hi Andrzejek,
Thanks very much for the info. I did check the pin was in the yellow plastic u shape bracket at the end of the manual shift mechanism and verified it moving while moving the shifter in side the car.
I took the valve body out again this morning and checked all my work and the sleeves, valves and springs are all in the righ place and moving freely.
I did the same thing as you - measured the amount of ATF I drianed out - a total of 5 quarts and put exactly the same amount back in. I am wondering if I lost a quart on the cardboard in the garage and in the valve body drain pan so have made my self a dipstick and calibrating it now per the specs I found on web (54mm low hot, 64mm high hot)
I am planning to clean the electrical connector and get the residual fluid out of it then install, following with refilling the transmission - will then let car run for a half hour and check the fluid level and top off accordingly
If it still wont shift in forward and reverse I figure I am screwed as something is up with either the contactor plate or something inside the valvebody causing low pressure in the clutches - cant imagine I damaged anything as I have been sooo carefull!
I will let you know how it plays out.
If the fluid level is not the issue then I am planning on purchasing a recon valve body from eurpoeantransmissions.com.
Thanks again for your help! :confused:
Dan
#4 · (Edited)
oh yes and I used Castrol Import Multi Vehicle ATF as well. Castrol website said compatible with Mercedes 236.x ATF specification. It seems lower viscosity (a bit thinner) than what I took out of it.
I noticed you used Valvoline Maxlife. I found several Jag owners using the Castrol in their transmission, basically the same as a Mercedes transmission, a 722.6
Any thoughts on this > Unlikely the problem huh?
Praying its the level causing it otherwise Im stranded grrr!
#5 ·
problem solved!
I think it was a badly seated elcectrical connector to the transmission or a sticky valve in the valve body. I removed all valves cleaned, lubricated and excercised them, reseated everything and filled up with Castrol Import ATF with my home made dipstick - with thanks to you all on this forum.
The transmission now functions flawlesly with the Sonnax sleeve kits. Shifts like Buttah!
Relief...time for a beer! :)
#6 ·
Back to Japan
Man, I had a similar experience. I had my trans serviced at a MB dealer. It is a 2003 C240 with 64k miles on it. (Creampuff I thought) I noticed on the work order that MB used Shell trans fluid. I said no big deal they must know what they are doing. Right? Then I read on these forums that using MB ATF is a must. WTF!
About a month after having the tranny serviced my tranny goes out. It wont go into park. Yep, when shifting to park the c240 just keeps going forward. I shut the engine down and had it towed to the mb dealer. They told me that a clip went out in the tranny and they fixed it for free (warranty). Man I'm lucky because I only had 5 days left on my extended warranty. MB extended warranty was awesome, it saved me a ton of money on 3 different repairs.
Needless to say I couldn't take the chance of a big repair bill with my warranty expiring in 3 days.
Thus, I traded my beloved 2003 c240 in for a 2010 Honda CRV 4 wheel drive. Even though my benz only had 64k on it--I got rid of it. I no longer trusted the vehicle and I felt that it was only a matter of time before I broke down on the road and got a huge repair bill. I'm talking 3 or 4 grand.
So this is my last post here at the MB forum. From now on, I'm sticking with the trouble free Japanese Brands.
Also, I will no longer buy certified used. I'd rather have a new honda with 48 miles than a certified used benz which I can't trust.
Sorry to rant and rave but I just had to vent. Man, I hated getting rid of that Benz.
P.S. A Benz is truly a wealthy person's car--not for the working class. LOL
